Results 1 to 10 of 10
Thread: CMI 6424-S hard drive terrible engine sound
    Default CMI 6424-S hard drive terrible engine sound
    Hello i bought this pretty rare hard drive, it works relatively good, there are no bad sectors, but problem is hard drive engine, sounds terrible.
    It is something what i can do with it or it is final condition?
    https://www.youtube.com/watch?v=RTzx...ature=youtu.be
    IBM PC 5150(A): IBM PC 5150(B): IBM PC 5160 (64-256k): IBM PC 5160 (256-640k): IBM PC 5170 (099): IBM PC 5170 (319/339): IBM PC 5140: IBM PC 5162: IBM PC 5155:
    WANTED! : IBM 5161 Expansion unit, IBM 5154 monitor, IBM EGA Graphics Memory Expansion Card, IBM PC screws,
    My IBM PC hardware collection
    Sounds kinda normal for a FH MFM.
    I've got some that sound much louder/worse.
    27,854
    20
    Probably the bearings are running dry, but this doesn't sound any worse than some of the old drives when they were new.
    Try running the drive upside-down for a few days to redistribute what's left of the bearing lube.
    definitely not, i have lot of FH MFM drives, ST-412, ST-4026, 4037, 4038, IBM type 13... you dont hear that high scratch tones on cca 0.25s?
    Is there some way to lubricate those bearings?
    27,854
    20
    Not really--the bearings are installed pre-lubricated. Any lubrication you might be able to add stands a chance of contaminating the medium.
    May 2011
    San Antonio, TX
    210
    Drives that old are very tough. You COULD try opening the drive (although personally I don't recommend it), and adding more lubrication. I've seen people open drives that size with no problems. It's like the drive surfaces made in those days needed to be about as clean as a modern CD in order to work properly. (Unlike the drives today that are so sensitive that simply opening them may do them in.)
    Quote Originally Posted by romanon View Post
    Barely...
    Maybe you are overreacting.
    Quote Originally Posted by T-Squared View Post
    Hey, you've managed to juxtapose a really bad idea and a really good idea.
  9. #9
    May 2011
    San Antonio, TX
    210
    Well, in my opinion, it's true. I've seen twice where someone has opened a physically-very-large-sized drive with a small data capacity (in the 5MB to 20 MB range.) to free the bearings or a R/W head under stiction. As far as I'm concerned, the drives are not only much tougher, but the equipment is less sensitive to airborne contaminants due to the size of the heads and the density of data on the platters.
    Someone's example of freeing the bearings on a Seagate: https://www.youtube.com/watch?v=Ur1hg0SUEWA
    BBISHOPPCM's repair on another hard drive for an IBM PS/2: https://www.youtube.com/watch?v=9rCH_HjY9WM
  10. #10
    27,854
    20
    Yes, but how about a YT video of someone lubricating the bearings in a 5.25" hard drive? It's pretty difficult as those bearings tend to be shielded types.
