Results 1 to 10 of 16
Thread: $2 Find: Macintosh IIci w/ Carrera040 Card
    Jan 2017
    California (92548)
    116
    Default $2 Find: Macintosh IIci w/ Carrera040 Card
    I picked this system up just recently from an e-waste facility for literally pennies. I know nothing about Macs (I've always been a PC guy), but it was too vintage and in too good of physical condition to just let it go to scrap. Getting it home, I found it was almost immaculately clean inside, with almost no dust or anything.
    I have no way to test it but I do know the PSU works, but the HDD sounds dead when firing it up. Its a very clean system physically, so I figure the chances are high that it does still work, beyond the HDD.
    Anyone have any suggestions on how I can test this further? Short of buying adapters or original Mac keyboard/monitor, that is. I really just want to see this go to someone who will keep it out of the scrap heap, but I'd like to be able to tell people a bit more about its condition. I also know very little about this Carrera040 card, beyond the fact that one (with an additional daughter board) sold on ebay for $180.
    Very neat find. Many vendors made cpu cards, you could plug a PPC into a Mac II. I tend to draw the line at the IIfx. Though I ain't got one yet. The IIci looks like a IIcx externally if I remember correctly, but was different somehow. Can't remember. Maybe I should look it up.
    You should here a chime when powering up
    Sep 2003
    Ohio/USA
    7,159
    ADB keyboards and mice should be easy and cheap to find in CA. The IIci has built in video and you will need a cheap adapter to connect it to a VGA monitor or LCD.
    Looks like there are 4x16MB SIMMs in there also.
    Systems of that age seem to have capacitor rot on the motherboard (easy enough to fix).
    Sep 2006
    Silicon Valley
    1,649
    the ci does not support vga scan rates
    Sep 2003
    Ohio/USA
    7,159
    640x480 8 bit. You might have issues with an LCD and scan rates but an old CRT should work.
    Jan 2017
    California (92548)
    116
    and 4x4MB SIMMS, so 80MB RAM total.
    I also notice these look at least physically identical to PC RAM from this period. Are they interchangeable?
    Sep 2003
    Ohio/USA
    7,159
    Apple RAM tended to not have parity chips (so 8 chips instead of 9 on a 30 pin SIMM so cheaper to make), PC's needed parity. So you can use PC memory on a mac but Mac specific memory might cause problems on a PC.
    5,427
    41
    You will need to do a recap. I've heard stories that the strangely packaged SMD ones on that era of Quantum drives like to go bad but I can clearly see the ones on the logic board are leaking, plus the power supply is known for needing new caps as well.
    = Excellent space heater
    Yep. My IIci NetBSD server is connected to an old school NEC multisync CRT.
    And yes, recap it. Almost every '030 Mac I run across nowadays has blown caps.
    Native Mac 640x480 has a hsync of 35khz. VGA is 31.5. Likely close enough that a twist of a trimpot on any VGA monitor would make it symc up.
