Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 71
Thread: Project: Micro 8088 - Chipset-based 8088 XT compatible processor board
    It's surprising how few POACH designs ever succeeded in the marketplace (e.g. C&T's F8680 or the ZF MIcro ZFX86). I wonder if the ultra-small PC is less sensitive to processor architecture and ARM-based designs are perfectly fine for the tiny PC market. I don't think Intel's Edison ever got anywhere either.
    I looked at making a 286 SBC like sergeys boards using C&T's F8680 or the C&T SCAT chipset, but they are going for like 30+ for one chip which is a bit much...
    31,239
    Well, I never figured them to be common. In a a decade they'll probably be even dearer.
    Jul 2010
    Silicon Forest, Oregon, USA
    718
    Quote Originally Posted by BloodyCactus View Post
    I always felt like 286 is a dead end processor. There is 386SX, which is just as good as 286, only much better I've seen a plenty of chipset based 386SX motherboards. It is possible some of these chipset are still available...
    Mar 2016
    Georgia, USA
    527
    Quote Originally Posted by sergey View Post
    A 386SX kit computer would be pretty neat. I don't think I've ever seen a loose CPU on ebay though...
    loads. hit ebay for '386 qfp'
    as a note, C&T had a chipset that I think was F82c836 was their 386sx chipset and F82c235 was their 286 chipset, from memory they were pretty much drop in compatible (since it was an SX only chipset, retained a 16bit isa bus). Teknor AT1 (286) and AT2 (386sx) were nearly identical designs, save for the chipset. I dont have a datasheet for the F82C836 chipset tho (I have one for the 235 chipset) to say with 100% accuracy.
    Mar 2016
    Georgia, USA
    527
    Aren't those all DX chips though? I don't see any SX chips there.
    It would appear most are dx. here is an sx.
    https://www.ebay.com/itm/111603310298
    10 pieces for 24$. amd sx 16mhz
    https://www.ebay.com/itm//160930346894
    Ive seen tubes of them come and go.
    Dec 2010
    Seattle, WA
    1,758
    If someone where going the QFP route, how about using an 80386EX ?
    https://www.ebay.com/itm/302240312198
    Do all of the integrated controllers in those have AT compatible modes?
    Jul 2010
    718
    If I remember correctly, 80386EX integrates some AT-compatible controllers (timer, interrupt controller). But for example DMA is not quite AT compatible, there is no keyboard controller, or RTC either. Also the 386EX by itself does not provide ISA bus interfacing, and some additional logic is needed.
    Jul 2010
    718
    And speaking of PC-on-a-chip, M6117C M6117D chips look interesting. (Of course if you're willing to solder 208-pin PQFP package with 0.5 mm lead pitch... But I know you are... because you've already soldered that TVGA9000i IC on my SVGA board).
    M6117 integrates a 386SX core, which apparently can run on up to 40 MHz speed, the whole AT chipset, and in case of M6117D, apparently chip selects for IDE, and some other goodies. All that for less than $20... Looks like a good deal
