Page 6 of 11 FirstFirst ... 2345678910 ... LastLast
Results 51 to 60 of 101
Thread: Project: Micro 8088 - Chipset-based 8088 XT compatible processor board
  1. #51
    Hello everyone, unfortunately the FE2010A is currently very poor available. I have the option to buy a "WDC FE2010A-JU"... Will it be the same like the original Fairchild FE2010A? In particular the "-JU" confuses me
  2. #52
    Mar 2018
    New Zealand
    104
    Quote Originally Posted by CrazySheriff View Post
    I haven't found any information about this one, but "9127" suggests it's perhaps a later model than the Faraday branded ones? My Faraday branded ones say "8625", but I'm not sure if that's a date code.
    There is one person online that has built a Micro 8088 with the "JU" one in his photo. I haven't checked to see if it works but I assume it does.
    https://www.assembly.site/micro8088.php
    Monotech PCs - brand new Vintage computer parts and accessories - Click here!
    EternalCRT: MDA/CGA/EGA>VGA Converter, XT-IDE, XT-CF-Mini, AdLib, DeluxeFloppy, PS/2>XT Keyboard Converter, XT-SVGA, NuXT, XT-MegaIO
  3. #53
    Thank you very much! That is the information I needed
  4. #54
    Mar 2016
    Georgia, USA
    633
    Western Digital bought Faraday, didn't they?
    I would take a gamble on that chip, I bet it works fine.
    On an unrelated note, I'm finally getting around to unpacking all my projects since I moved to a new house. Hope to get back to my micro8088 real soon now.
  5. #55
    Mar 2018
    New Zealand
    104
    They did in July 20 1987.
    Googling gives me four different looking FE2010A chips.
    One of them is the one marked FE2010A-JU above. I suspect that's a later model after the WD acquisition. "J" possibly being related to the J-leads of the PLCC package. Modern chips often have J in the model number for PLCC.
    "9127" is probably 27th week 1991.
    The other three have the Faraday branding. Some have a likely date code, such as the following "8806":
    Some have a random looking number between JAPAN and delta symbol.
    Such as the one in Sergey's board: https://github.com/skiselev/micro_80..._Board-1.1.jpg
    Sergey's says 7Z10. My own chips say 073012 here.
    Then these on Google images from an expired eBay listing, which say "Faraday '88", and have what looks to be a 1990 date code.
    So perhaps the FE2010A-JU chips are the last manufactured ones, in 1991.
    I have some of these on the way, and will update. I have little doubt they'll work.
  6. #56
    Jul 2010
    Silicon Forest, Oregon, USA
    726
    I've tested Micro 8088 with WDC FE2010A-JU. It works just fine.
  7. #57
    Quote Originally Posted by nztdm View Post
    I want to build one of these but I can't find the chip myself, might you divulge your source?
  8. #58
    Mar 2018
    New Zealand
    104
    Quote Originally Posted by almoerman View Post
    I am also looking for more, as my two vendors are dried up; I don't have many.
    PM me if you'd like to buy one.
  9. #59
    Hi!
    I have a Micro8088 assembled and everything works fine. However, the CheckIt program gives an error on DMA channel 0. Tested with 74HC573 chips and also with 74F573. Does anyone know what the cause may be? and if it has any more involvement in the performance of the system other than the failure reported by the checkIt program?
  10. #60
    Mar 2018
    New Zealand
    104
    Quote Originally Posted by spark2k06 View Post
    Hi!
    That is normal, and related to not using DRAM. You can ignore it
