Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Kryoflux folks looking for hard sectored disks
    Jun 2003
    Northwest (UK)
    380
    I've just bought one of new machined metal versions from a chap over on the Heathkit group. Pretty much the same design and a great bit of kit. I've just punched a disk but have not yet tested it. H8 is still in bits
    Cheers,
    Feb 2006
    in the basement
    869
    ...One can then rotate the envelope to move the index window to
    the next location to punch. The trick is to have the punch through
    the hole in the floppy when clamped...
    Thank you for the explanation Dwight.....I got it now !
    The sector holes on the plastic piece threw me off as I had assumed
    one index hole on the upper disk rotating to the next position would
    have been enough. But the upper disk and those peep holes are fixed
    in place to help for accurate alignment of the index hole and letting
    the punch through.
    I assume the two screws on the metal disk are holding a lower
    plastic disk (flange shape) that protrudes through the metal disk...
    Now Dwight....did you do the machining yourself, or you had it done by
    a machine shop?
    ziloo
    Quote Originally Posted by ziloo View Post
    the punch through.
    a machine shop?
    ziloo
    It was done in a shop. Another fellow had a friend with a shop. The screws hold the stainless metal plate to the turned plastic.
    The two have are aligned by the pin sticking up radially aligned, at 90 degrees, with the index hole. What the picture doesn't show is that the top piece has a hole bored into it that fits the center piece of the bottom piece. This is the same way that a disk drive holds the floppy centered. It would have been better to have 2 alignment pins but this is the way the fellow with the shop did it.
    Dwight
    Feb 2006
    in the basement
    869
    ....the top piece has a hole bored into it that fits the center piece of the bottom piece...
    It is like a cylindrical cavity that fits the bottom center cylindrical piece...?
  5. #15
    Yes.
    Dwight
  6. #16
    Feb 2006
    in the basement
    869
    Double post again..
  7. #17
    Feb 2006
    in the basement
    869
    Brilliant discussion Dwight for anybody who wants to
    make his own jig (after you are out of stock )..
    ziloo
  8. #18
    ziloo
    I'm out of the 10 sector ( keeping one for myself ). I do have 16 sector punches left. One might post to SEBHC to see if any new 10 sector punches are left or someone wants to part with one.
    Dwight
  9. #19
    Have a look at the Athana website - "Specialty Diskettes are also available: Hard Sector, ..."
    http://www.athana.com/html/diskette.html
