Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Got IBM 5251 display terminal
  1. #21
    Jun 2013
    Montevideo, Uruguay
    371
    Yes will have to pull the guts of the monitor out to fix it, and the brightness and contrast control are not done in the crt they are done at the "digital board" from the documentation they just up the video signal -/+ that goes to the monitor.
    Not sure if this means that maybe my video signal is to low ?, the levels from the cga card must be less than a 1v
  2. #22
    Jun 2013
    Montevideo, Uruguay
    371
    ok now works finally
  3. #23
    Very nice!
    That is a strange looking PCB. Are there traces on the underside of it? Did they just drop the IC's in and wave solder it leaving all the squares of filled in solder on the top?
  4. #24
    Oct 2008
    Kamloops, BC, Canada
    5,667
    43
    hnnng, that crisp green screen. I'm so jealous you have a complete unit.
    = Excellent space heater
  5. #25
    Mar 2006
    Salt Lake City, UT, USA
    295
    Quote Originally Posted by soviet9922 View Post
    What did you end up doing to get it working?
    I assume you're driving it as a CGA/MDA display?
  6. #26
    Jun 2013
    Montevideo, Uruguay
    371
    I hooked it up to a small very small mini pc that i found in a flea market it boots from a compact flash, and have 2 gigs of ram.
    Then i got a board that is sold on ebay goes in the keyboard to make it usb compatible, using this i can run this is as a dumb serial terminal or like a full computer.
    I could have prefered using an older motherboard its a shame the usb keyboard converter don't work in ps/2 mode.
  7. #27
    Jun 2013
    Montevideo, Uruguay
    371
  8. #28
    Quote Originally Posted by alank2 View Post
    I guess you mean the board attached to the back half of the case. I've very limited electronical knowledge, but I can show you some hires pictures of it:
    Front: https://i.imgur.com/ZRjJjDH.jpg
    Back: https://i.imgur.com/qe37lPb.jpg
    explanatory sticker from inside the case: https://i.imgur.com/uost4h1.jpg
    Do you think there is a way to explain/show to a non-electrician like me how you connected the mini-pc to the 5251 monitor?
