Results 11 to 20 of 28
Thread: Got IBM 5251 display terminal
    Mar 2009
    Dublin, CA USA
    2,757
    Before gutting the thing and re-purposing it keep in mind that they go for quite a few dollars on ebay. I sold the one I had for nearly $600 and that was a steal compared to some I've seen sell on Ebay, heck someone offered me nearly $400 for just the keyboard.
    So even though you are in Uruguay you may actually find someone crazy enough to pay the freight to get it from you...
    Jun 2013
    Montevideo, Uruguay
    368
    Yes but MDA and CGA have diferent horiz freq cga is 15 khz and MDA 18khz if i remember correctly
    31,760
    My recollection is that it was pretty simple to re-tune the Fujitsu units upwards to make very decent monitors. Monochrome displays aren't rocket science.
    Jun 2013
    Montevideo, Uruguay
    368
    Hooked horizontal vertical ground and video to a CGA card now the monitor sync start i can hear it.
    The flyback transformer get active i have a small neon bulb i use for testing it.
    But now picture in the tube none nada pure 100% black.
    Not sure what could cause this.
    31,760
    It's not black when hooked to the terminal innards?
    Jun 2013
    Montevideo, Uruguay
    368
    When is hooked to the terminal innards the unit do nothing the monitor don't get even sync.
    31,760
    Sounds as if there's a more serious problem. Can you see the CRT heater glowing?
    Jun 2013
    Montevideo, Uruguay
    368
    Yes the heater glows, and the hv flyback is working but there 0 brightness in the tube never run on a monitor having this problem before.
    31,760
    Well, most of the old monochrome OEM monitors follow a standard design. Time to get the 'scope and DMM otu and run down where the thing is failing, perhaps.
    5,659
    43
    I am assuming you have tone the sanity check and verified the brightness and contrast are not turned all the way down.
    = Excellent space heater
