Results 1 to 6 of 6
Thread: IBM eduquest 55 - info?
    Default IBM eduquest 55 - info?
    I recently came into possession of what I assume is an Eduquest fifty five. (image attached)
    I read it as fifty five, though I will admit it might be a thirty five. I just can't tell. The price was unbeatable in either case so once it gets here tomorrow, I will know for sure. I have my doubts as according to the tracking number it is currently just outside of Omaha, NE and no matter how many times I press F5 it hasn't moved.
    Yes, like a kid on Christmas eve, I'm "excited". To say the least.
    So, doing some preemptive research, I have come up a bit dry. I'm fairly certain it has sound. I'm not overly interested in token ring, but it would give me an excuse to break out the MCU. I was told it booted, and it had 15mb of ram, and has the symptoms of a dead battery. (shocking) the 15mb of ram, I hope is a typo, 16 makes much more sense, and if he is correct, it would be a concern to me. I don't doubt the guy I'm getting it from. I honestly just jumped headfirst into this.
    so, ultimately i'm asking the following;
    1. any pitfalls that I should avoid? I'm going to treat this thing like a Model 25 for now.
    2. any particular images anyone want? - I will post proper images here once I get it, don't worry.
    3. Rom dumps? Hard drive files? etc?
    4. upgrade options? - I have a POD-83 I assume will work.
    It is a mistake to think you can solve any major problems just with potatoes.
    3,555
    These were the newer machines found in our computer labs in gradeschool -- the older ones were Model 25s. All of ours had Model M spacesaver keyboards in the computer labs, sometimes full-size Model Ms if they were on their own in a classroom or the library. There must've been an Ethernet option for them as everything in the county was Ethernet. I believe the EduQuests used 10base2, I seem to recall the labs being daisy-chained for an entire table.
    They ran some IBM network system, forget what it was called, but the splash screen was a white text on blue background ASCII IBM (e.g. IBM spelled out in huge block letters). They booted DOS from the local disk and loaded the network system, mounted some drives, and put you in a menu system where you could choose various educational things (typing tutor, etc.) or boot into Windows 3.1.
    Yea, I got a full sized keyboard with it also. As hard as it is to get IBM PS/2 machines with sound I might actually use it for games. ^.^
    Got the machine early today.
    It is a 55. It boots into windows 95, but the sound drivers are missing. The config was solved with a new 2032 battery. It looks like it HAD a network card, but its gone. the 15mb this was an error, the guy didn't add the 640k in. 66mhz with NO heatsink, 16mb ram and a 1gb hard disk.
    So, it looks like it uses standard simms. I'm going to be testing the limits this board will take. I even have some 128mb dimms to try. (a highly unlikely possibility it will work, but I might as well try)
    The L2 cache chips are missing, and it looks like it will accept standard 32 pin srams.
    TO DO:
    upgrade to scsi
    max dram/sram/vram
    clean and retrobrite?
    Feb 2006
    Jacksonville, Florida
    1,167
    I did find both of those sites quite easily. I do have them bookmarked from other projects.
    I did take it apart last night and gave it a good cleaning. It is actually a REALLY nice chassis. They even have doors to make it easy to access the 5.25" bay. I kinda miss the tilt of the model 25, but honestly the larger screen makes up for it.
    I noticed the sound card is SUPER close to the top of the simms in this machine. So it will make it slightly annoying to find high capacity simms, and keep them short.
