Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: New TestFDC Results Registry
  1. #21
    35,181
    SMSC chips are generally very capable as well.
  2. #22
    Thanks for your updates TestFDC.
    I did some test yesterday and have a question.
    CA9277B Advanced Super I/O Controller with N82077SL FDC.
    My problem sometimes is to find the correct result as on 360k floppy SD at 250 failed and on HD-floppy it was not tested.
    So I interpreted the Result as follows
     Data  Rate
     250  300  500
     SDX  SDX  SDX
     FPF  PPF  PPF
    Hardware SlotCPU AMD386-33  , Matrox VGA, 3C509 NIC
    TESTFDC.COM
    A: 360kb
    Report on FDC capabilities, issued 21/06/2020 19:43:34:
    Single-Density at 250 kbps ............................ Failed
    Single-Density at 300 kbps ............................ Not tested
    Single-Density at 500 kbps ............................ Not tested
    Double-Density at 250 kbps ............................ Passed
    Double-Density at 300 kbps ............................ Not tested
    Double-Density at 500 kbps ............................ Not tested
    Double-Density at 250 kbps / 128 byte sectors ......... Failed
    Double-Density at 300 kbps / 128 byte sectors ......... Not tested
    Double-Density at 500 kbps / 128 byte sectors ......... Not tested
    B: 1,2MB
    Report on FDC capabilities, issued 21/06/2020 19:49:47:
    Single-Density at 250 kbps ............................ Not tested
    Single-Density at 300 kbps ............................ Passed
    Single-Density at 500 kbps ............................ Passed
    Double-Density at 250 kbps ............................ Not tested
    Double-Density at 300 kbps ............................ Passed
    Double-Density at 500 kbps ............................ Passed
    Double-Density at 250 kbps / 128 byte sectors ......... Not tested
    Double-Density at 300 kbps / 128 byte sectors ......... Failed
    Double-Density at 500 kbps / 128 byte sectors ......... Failed
  3. #23
    35,181
    I believe that I noted the inconsistent issue a couple of years ago. I believe I uploaded a much simpler version of the tool at the time.
    But the Intel 82077AA-1 definitely has issues with FM and doesn't do 128-byte MFM, period.
