Results 1 to 10 of 11
Thread: IBM EGA 5154 Monitor - too bright?
    Default IBM EGA 5154 Monitor - too bright?
    I've got this 5154 that seems to be very bright. When you turn the brightness all the way down, its like the picture goes darker, but the raster stays illuminated. With the brightness all of the way down, you can still see some of the game on the screen in this video.
    I've talked with other 5154 owners and this is not normal. Anyone know what would cause this, or how to fix it? I don't think its ever been serviced. Would a capacitor cause this or something else? Just an adjustment?
    I should add that I don't see the problem on this page for this monitor.
    http://minuszerodegrees.net/video/Mo...0Database.html
    https://youtu.be/cSJidMPWkgw
    I have a Major in Post-Apocalyptic Economics.
    Wanted: Any PC-Compatible Reciprocation Dingle Arm
    6,987
    I think you're confusing the brightness knob with the contrast knob.
    No, its at the end of the video.
    6,987
    Okay, had to watch it with sound so that I could understand what you were doing, since without sound it looks like the monitor is working perfectly. So, yes, the black level is supposed to decrease when you turn the brightness all the way down. So, some of your components are failing. The good news is that a capacitor replacement will likely fix the issue.
    Here’s a better video
    6,987
    Yes, that needs recapping.
    Turkey, Ankara
    124
    I'd decrease the screen (G2) control on flyback transformer first before recapping the monitor. It could be misadjusted by its previous owner for some reason.
    IBM 5150 - IBM 5155 - IBM 5160 - IBM PS/2 Model-60 (8560-041) - IBM PS/2 Model 55 SX with 8503 - IBM PS/2 Model 35 - IBM PS/2 Model 80 (8580-X21, XGA2) - IBM PS/2 Model-30 (8530-021, IBM 8513) - IBM PS/2 Model-30/286 (8530-H31) - IBM PS/1 (2133-642) - IBM PS/1 (2155-593) - IBM PC 330 450DX2 (6571-KV1) - TANDY 1000 TL/2 - Turbo XT Clone - Wearnes Boldline (80286/16) - Hyundai SUPER386ST (386SX/25) - AST AdvantagePro! (486DX/33) - Olivetti PCS46/C (486DX2/50), - 386DX/40 System - AMD K6-2/400 System - Pentium PRO/200 System
    It's also possible that the flyback itself is shot.
    I adjusted the flyback control... no immediate difference was noticed, but.... I left the computer and monitor on for about 90 mins and the issue went away. Seems to go away when the unit warms up. I turned it off and on but the monitor was warmed up and didn’t do the brightness raster thing... I’m guess omg it will happen again when starting the monitor cold.
    Turkey, Ankara
    124
    Quote Originally Posted by offensive_Jerk View Post
    Then probably some of the caps in the video and CRT drive sections are high in ESR and need to be replaced. ESR goes down with increasing temperature in electrolytic caps and symptoms disappear.
