Results 1 to 4 of 4
Thread: No Screen displayed for IBM P70 - Suggestions to troubleshoot??
    Jun 2012
    Livermore, CA
    164
    Default No Screen displayed for IBM P70 - Suggestions to troubleshoot??
    I was cleaning up the case of an IBM P70 for a friend. It was working. I booted it up and OS/2 loaded up from the hard drive as it should. I used it for a couple hours, and shut it down. I drove it back to my friends house, about 30 miles. It sat there for a few days. When he booted it up again. he had no screen display. I went back over and yes no screen displayed. The Hard drive sounded and felt like it was load OS/2, but obviously can't confirm. There is no external VGA port on this unit. The floppy drive is bad. It was the classic issue of a couple blown caps on it's pcb. I found this out while cleaning it. It was working with this fault.
    This is the first one of these I have working on. Suggestions to trouble shoot the screen?
    Many Thanks
    Atari Falcon 030/FX-1 CF & SD 14mb, Atari MSTE, Atari PS3000, STACY 4 /w UltraSatan SD, 4160STE-CosmosEX, Atari PC1-PCH204-2xPCF-551-PCM124, 1040STFM, 1040STF, 520ST(4mb, 16mhz), 400-48K & std kybrd, 800, 600XL, 800XL, 1200XL(256 Rambo,svideo,31-OS,APE upgrade), 130XE, XEGS, matching peripherals for all,
    Apple llGS ROM 3-4mb-CF HD, C64, 4+, IBM XT 5160, IT 99/4+, TRS80-4P, Amiga 500,
    Jun 2012
    Livermore, CA
    164
    No one has any experience with these?
    Oct 2008
    Kamloops, BC, Canada
    5,141
    41
    You did not mention that you reseated the video subsystem boards when you troubleshooted. All I can think of is something was jostled loose. Do you have any way to confirm the gas plasma panel is even going live?
    = Excellent space heater
    Apr 2012
    Deventer, the Netherlands
    51
    I once had to replace an electrolitic cap on the video card to get the display on my P70 working again.
