Results 1 to 10 of 10
Thread: Boards that fail to post.
    Sep 2016
    Melbourne, Australia
    619
    Default Boards that fail to post.
    This board came from a recycler and while not a first generation pentium board it has something to offer in the way of information
    When I got it, it failed with a post code of C1, the BIOS was unable to detect the RAM installed. To solve the problem I replaced the bloated electrolytic capacitors. There were 10 in total and they are marked in red.
    After replacing them the board works perfectly. The caps marked in green are solid capcitors and were fine.
    I have another socket 775 that is a couple of years older, it worked for a short time and then failed and now shows no POST activity at all. This board does not use solid caps around the CPU and every one of those caps is swollen.
    The capacitors I have on hand are slightly too large to fit in under a CPU cooler so I've ordered some solid capacitors that will fit to replace the electrolytics around the cpu. I fully expect replacing those caps with bring the board back to life.
    So the lesson to be learned from these boards.... don't throw away a board that doesn't pass a BIOS POST test. In all likelihood $2 worth of capacitors from ebay will bring it back to life.
    Jan 2013
    Marietta, GA
    2,900
    Not bad. What method did you use to remove/install the capacitors? Desoldering these things can be a pain on newer boards.
    Jan 2010
    Central VA
    4,152
    Weird stuff happens when the caps start to go, but haven't totally popped. I bet the cap plague from those years eventually makes P4s actually rare.
    Mar 2012
    Augusta, Georgia, USA
    535
    Yep - early to mid 2000's technology will be mostly lost to history due to defective cap death.
    29,632
    20
    On the other hand, some really good mid-2000 boards go for silly cheap because of easily replaced caps. So the issue cuts both ways.
    May 2011
    San Antonio, TX
    217
    I used to have problems desoldering caps/components on a Zenith Supersport system, until I realized that more heat works. (The board is multi-layer, so the copper vias absorb the heat.)
    Apr 2015
    Austin, Texas
    1,305
    Quote Originally Posted by SomeGuy View Post
    I'd recommend a desoldering station with a really powerful heating element. I have an 80W unit and it works on 99% of the boards I work with. Some boards with really thick ground planes will give it trouble, especially if ROHS solder is used and I'll have to break out the hot air station to get it working.
    I don't recommend using one of those spring loaded desoldering tools because the fast sucking action can cause the solder to freeze with bubbles inside the hole and in some cases you'll have to resort to drilling it out.
    I've got a similar motherboard in my Windows 7 PC... minus the parallel port, and it's been working for about 8 years now. Yours is an Athlon/Phenom board right? I've got my Athlon x4 overclocked to 3.5ghz and can still manage modern games even.
  9. #9
    Sep 2016
    619
    Because most of the replies on this thread were lost to the data gremlins I thought I'd give an update. I've managed to bring 9 out of 10 formerly dead boards back to life.
    The easiest way I've found to remove the caps is a large 80W non temp regulated soldering iron with a tip about 9mm in diameter. I originally bought it for desoldering pcb mounted heat sinks.
    I simply place the motherboard upside down, flow a little fresh solder onto each leg of the cap then place the tip of the iron across both leads and they drop right out of the board.
    I clean up the holes with a vacuum desoldering station I got off ebay. Some can be stubborn so you need to run it at about 450C and give plenty of time for the heat to melt the solder all the way through.
    I generally replace electrolytics with new solid capacitors, but a couple of older boards I've had to use electrolytics again due to lead spacing and physical size constraints.
    Also if you have newer boards you are scrapping its worth the effort of recovering the caps (from around the CPU in particular), sometimes finding caps in that low profile can be difficult.
    Edit: I did have a couple of holes that were extremely stubborn and resisted all attempts with the desoldering station. For those I used the larger iron and when the solder was fully molten slipped a wooden toothpick into the hole. Its crude but surprisingly effective.
  10. #10
    29,632
    20
    I supplement heat on these with a 325W soldering gun. Works a treat.
