Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: TI-74 Basic programs?
    Default TI-74 Basic programs?
    I'm not sure if this the proper place to post this, but does anyone have any TI-74 Basic language programs they'd like to share?
    Like I've said, I'm no programmer, but I have couple that might be useful. The more I play with the 74, the more I'm fascinated by it. I'm finding more and more reasons to use it; from storing readily available passwords offline to helping me do my bills. Nobody can peek or poke around in this machine or track me while I'm using it. As best I can tell, it's totally secure.
    If you do have any programs, just post them here so all can benefit.
    The 74 may be old, but it's a great little machine....and puts us completely in charge.
    Thanks.
    Like said, I'm no programmer. But here's a program to calculate the gearing of your bicycle in 'gear inches'. (check my math
    100 PRINT "Gear Inches": PAUSE 1
    110 PRINT EQA;"> wheel dia,in. ";: ACCEPT NULL(EQA),EQA
    120 PRINT EQB;"> rear tooth #,fw. ";: ACCEPT NULL(EQB),EQB
    130 PRINT EQC;"> front tooth #,crank ";: ACCEPT NULL(EQC),EQC
    140 EQX=(PI*EQA)/(EQB/EQC): EQY=(EQX/12): EQZ=EQC/EQB*EQA
    150 PRINT USING "dist crank rev,in. ###.###";EQX: PAUSE
    160 PRINT USING "dist crank rev,ft. ###.###";EQY: PAUSE
    170 PRINT USING "wheel dia equiv,in ###.###";EQZ: PAUSE
    180 GOTO 100
    WHEEL DIAMETER, inches, overall rear rim/tire diameter (26")
    REAR TOOTH COUNT, tooth count of desired free wheel/cassette sprocket (34t)
    FRONT TOOTH COUNT, tooth count of desired crank sprocket (28t)
    DISTANCE, CRANK REVOLUTION, inches, distance bicycle travels in one crank revolution (67.267")
    DISTANCE, CRANK REVOLUTION, feet, distance bicycle travels in one crank revolution (5.606')
    GEAR INCHES, inches, the gearing effect wheel diameter equivalent in inches (21.412" whl/dia)
    Pretty cool, Thumbs. I've got a bicycle dynamometer program somewhere -
    I'll see if I can find it.
    Jack
  4. Default
    I have a difficult time keeping track of passwords. I don't like leaving passwords around on scraps of paper. And I don't leave important information in any device that has access to the outside world. Here's a program that I use on my 74 to keep track of my passwords.
    1 Z$="": PRINT "Usernames Passwords": PAUSE 1: GOTO 18000
    1000 DATA 1,<retail username password>
    1010 DATA ABCD aaaa 1234a5,ABCD bbbb 2345b6
    1020 DATA ABCD cccc 3456c7,eof
    1100 DATA 2,<automotive username password>
    1110 DATA ABCD xxxx 1234x5,ABCD yyyy 2345y6
    1120 DATA ABCD zzzz 3456z7,eof
    18000 PRINT Z$;" > ";: ACCEPT NULL(Z$),Z$: PRINT ">..";: RESTORE
    18005 IF Z$="" THEN Z$="1"
    18010 IF Z$="0" THEN PRINT: GOTO 1
    18015 READ A$: IF A$=Z$ THEN 18040
    18020 IF A$="end" THEN PRINT Z$;" not found": Z$="": PAUSE: GOTO 18000
    18030 GOTO 18015
    18040 IF A$="eof" THEN PRINT "> end..": PAUSE 1: GOTO 18000
    18050 PRINT A$: PAUSE: READ A$: GOTO 18040
    32000 DATA eof
    32010 DATA end
    Have not played enough with my TI-74 and I need to!
    One of the first things I did when I got it back in Dec '16 was benchmark it calculating the factorial of a given number, the TI-74 fared better than the portable Tandy PC-6 and I made a short video of it -> https://youtu.be/Kv8epjcPcKk
    The program is by all means simple and straight forward...
    100 ! Factorial
    110 INPUT "Number to Factorial? ";N
    120 IF N=0 THEN PRINT 0:PAUSE:STOP
    130 F=1
    140 FOR I=1 TO N
    150 F=F*I
    160 NEXT I
    170 PRINT N;"!=";F=PAUSE
    180 END
    Completely agree that this portable is a joy to use. As I said, there is a LOT more to do with it. Cheers!
    Rogelio Perea
  6. Default
    Here are some miles per gallon programs I use. My old cars only have speedometers in MPH, so the input distances are in miles. I've used the first program when I've traveled through Canada. The second program is more direct using inputs. The third program I use when I have the 74 with me and don't wish to write info on paper. Since the 74 doesn't seem to store program variable info, I enter the variable info directly into the program for storage.
    (edited to correct for undesired emojis -- no space in line 2400, RM$="")
    2000 PRINT "Gas Mileage":PAUSE 1
    2010 PRINT "Clear y-n ";AM$;" ";:ACCEPT NULL(AM$),AM$
    2015 PRINT "Fill tank now...":PAUSE
    2020 IF AM$="y"THEN 2400
    2030 PRINT "Start mileage";BM;:ACCEPT NULL(BM),BM
    2040 PRINT "Drive..refilled tank? y-n ";CM$;" ";:ACCEPT NULL(CM$),CMS
    2041 IF CM$="y"THEN 2045
    2042 PRINT "Drive..then refill tank":PAUSE :GOTO 2040
    2045 PRINT "End mileage";DM;:ACCEPT NULL(DM),DM
    2050 PRINT "Refill (g)al or (l)iter ";EM$;" ";:ACCEPT NULL(EM$),EM$
    2060 IF EM$="g"THEN 2100
    2070 IF EM$="l"THEN 2200
    2080 PRINT "g or l...":PAUSE :GOTO 2050
    2100 PRINT "Gallons added";FM;:ACCEPT NULL(FM),FM
    2110 WM=(DM-BM)/FM:XM=((DM-BM)*1.6093472)/FM
    2120 YM=(DM-BM)/(FM*3.785332):ZM=((DM-BM)*1.6093472)/(FM*3.785332)
    2130 GOTO 2300
    2200 PRINT "Liters added";GM;:ACCEPT NULL(GM),GM
    2210 WM=(DM-BM)/(GM*.26417):XM=((DM-BM)*1.6093472)/(GM*.26417)
    2220 YM=(DM-BM)/GM:ZM=((DM-BM)*1.6093472)/GM
    2230 GOTO 2300
    2300 PRINT USING"mi/gal ###.##";WM:PAUSE
    2305 PRINT USING"km/gal ###.##";XM:PAUSE
    2310 PRINT USING"mi/liter ###.##";YM:PAUSE
    2315 PRINT USING"km/liter ###.##";ZM:PAUSE
    2320 PRINT "Again y-n ";RM$;" ";:ACCEPT NULL(RM$),RM$
    2330 IF RM$="y"THEN 2000 ELSE 2300
    2400 BM=0:dM=0:WM=0:XM=0:YM=0:ZM=0:FM=0:CM$="":EM$="":R M$="":GOTO 2030
    Example:
    Clear y-n y
    Start mileage 1000
    Drive..refilled tank y-n y
    End mileage 1100
    Refill (g)al or (l)iter g
    gallons added 10 (10 gal = 37.85 liter)
    mi/gal 10
    km/gal 16.09
    mi/liter 2.64
    km/liter 4.25
    2000 REM RUN 2000
    2010 PRINT "Start miles";START;:INPUT "";START
    2020 PRINT "End miles";ENDM;:INPUT "";ENDM
    2030 PRINT "Gals added";GALS;:INPUT "";GALS
    2040 MPG=(ENDM-START)/GALS
    2050 PRINT "MPG =";MPG:PAUSE:GOTO 2010
    2000 REM RUN 2000
    2010 START=1000
    2020 ENDM=1100
    2030 GALS=10
    2050 PRINT "MPG =";MPG:PAUSE:END
    Hi Thumbs - It's possible to store data above the high memory pointer
    (assuming you have RAM above the high memory pointer), & it will sur-
    vive power cycling, & (usually) crashes.
  8. Default
    Thanks Jack.
    That's good to know. I'm stilling trying to get deeper into the 74.....it may take a while
    My cardiologist said I should lose weight. So, I went online to find information on calories so I could do something on my TI-74. I found this website,
    http://www.seacoastonline.com/articl...TAIN/704120346
    Read their website for more details and complete information. They have information on maintaining calories. If I understand it correctly, anything over your desired weight maintaining calories, you gain weight and anything under you lose weight. Below are several routines I made using their math and examples. The routines seem to yield the example results they gave. I'm no programmer or dietition, so double check any results.
    The first two routines are short and direct. The third is more descriptive.
    20000 REM (for men) AL=activity level 1.2 1.375 1.55 1.725 1.9
    20010 LBS=175:HTIN=72:AGE=30:AL=1.55
    20020 PRINT "INT((66+(6.23*LBS)+(12.7*HTIN)-(6.8*AGE))*AL)":PAUSE:END
    To use the above routine (for men), seed the variables on line 20010; LBS=desired weight in pounds, HTIN=height in inches, AGE=age in years, AL=activity level, sedentary 1.2 to extra active 1.9
    Then, RUN 20000, press [ENTER], press [SHIFT] [PB] [ENTER] for maintaining calories (2893).
    Do similar to use the (for women) routine below.
    20100 REM (for women) AL=activity level 1.2 1.375 1.55 1.725 1.9
    20110 LBS=140:HTIN=66:AGE=30:AL=1.55
    20120 PRINT "INT((655+(4.35*LBS)+(4.7*HTIN)-(4.7*AGE))*AL)":PAUSE:END
    For a more menu driven routine, type in the routine below and RUN 20500.
    20500 PRINT "Maintain Calories":PAUSE 1
    20505 PRINT MW$;" (m)an or (w)oman ";:ACCEPT NULL(MW$),MW$
    20510 PRINT LBS;"desired lbs ";:ACCEPT NULL(LBS),LBS
    20520 PRINT HTIN;"height inches ";:ACCEPT NULL(HTIN),HTIN
    20530 PRINT AGE;"age ";:ACCEPT NULL(AGE),AGE
    20540 PRINT "1=sedentary 2=lightly active":PAUSE
    20550 PRINT "3=moderately 4=very active":PAUSE
    20560 PRINT "5=extra active":PAUSE
    20570 PRINT AL$;" activity level 1-5 ";:ACCEPT NULL(AL$),AL$
    20580 IF AL$="1"THEN AL=1.2:GOTO 20640
    20590 IF AL$="2"THEN AL=1.375:GOTO 20640
    20600 IF AL$="3"THEN AL=1.55:GOTO 20640
    20610 IF AL$="4"THEN AL=1.725:GOTO 20640
    20620 IF AL$="5"THEN AL=1.9:GOTO 20640
    20630 PRINT "error..1-5":PAUSE:GOTO 20540
    20640 IF MW$="m"THEN 20670
    20650 IF MW$="w"THEN 20690
    20660 PRINT "error..m w":PAUSE:GOTO 20505
    20670 SCM=(66+(6.23*LBS)+(12.7*HTIN)-(6.8*AGE))*AL
    20680 PRINT "Maintain calories";INT(SCM);"@";LBS:PAUSE:GOTO 20500
    20690 SCW=(655+(4.35*LBS)+(4.7*HTIN)-(4.7*AGE))*AL
    20700 PRINT "Maintain calories";INT(SCW);"@";LBS:PAUSE:GOTO 20500
    Examples for 20500 routine:
    Man, LBS=175 HTIN=72 AGE=30 AL=3, Maintain calories=2893
    Woman, LBS=140 HTIN=66 AGE=30 AL=3, Maintain calories=2221
  10. Default
    I was helping my grandson rebuild his air-cooled VW Beetle engine. He needed to determine his compression ratio for each cylinder. We went online and found compression ratio calculators. Most were for engines with head gaskets and possibly dome/dished pistons which he has neither. He has 87mm cylinders with flat pistons, no head gasket, and a 69mm stroke. I made this program for the TI-74 a little more specific to his situation. For comparison, we used this websites calculator,
    http://www.csgnetwork.com/compcalc.html
    If we entered the head gasket bore diameter as, 0 and the head gasket thickness as, 0 and dome/dished piston volume as, 0 with a deck height of 1.5mm it yielded, 7.962 to 1 Comp/Ratio with total displacement volume of 58.917cc (that's his combustion chamber 50cc + his deck height displacement of 8.917cc)
    It looks like the TI-74 is yielding similar results as the online calculator. Like I've said before, I'm no programmer or engineer, so check over the results for yourself. At any rate, he used the 74 to determine his compression ratio as it was easier to use.
    4000 PRINT "Comp/Ratio Air-cooled VW":PAUSE 1
    4010 PRINT BMM;" bore,mm ";:ACCEPT NULL(BMM),BMM
    4020 PRINT SMM;" stroke,mm ";:ACCEPT NULL(SMM),SMM
    4030 PRINT DMM;" deck height,mm ";:ACCEPT NULL(DMM),DMM
    4040 PRINT HCC;" comb chamber vol,cc ";:ACCEPT NULL(HCC),HCC
    4050 CYLD=BMM^2*SMM*.0031416/4
    4060 DHDP=BMM^2*DMM*.0031416/4
    4070 COMR=(CYLD+DHDP+HCC)/(DHDP+HCC)
    4080 PRINT USING"Compression Ratio ##.###";COMR;:PRINT " to 1":PAUSE
    4090 PRINT USING"Deck Height Disp,cc ##.###";DHDP:PAUSE
    4100 GOTO 4000
    Example:
    BORE=87mm
    STROKE=69mm
    DECK HEIGHT=1.5mm
    COMBUSTION CHAMBER VOLUME,cc=50cc
    COMPRESSION RATIO to 1= 7.962
    DECK HEIGHT DISPLACEMENT,cc= 8.917
