View Poll Results: What type is drive 0 on your Model 4?
Voters
21. You may not vote on this poll
  • Single-sided double-density 40 track
    7 33.33%
  • Double-sided double-density 40 track
    8 38.10%
  • Single-sided double-density 80 track (5.25" or 3.5")
    0 0%
  • Double-sided double-density 80 track (5.25 or 3.5")
    1 4.76%
  • HxC/Gotek/etc. flash drive
    4 19.05%
  • Other (no drive, 8", etc.) - list in the thread
    1 4.76%
Results 1 to 10 of 11
Thread: Model 4 drive 0
    Default Model 4 drive 0
    I'm curious as to what configurations people have for drive 0 on their Model 4 systems.
    Jan 2011
    Portland, Oregon
    626
    Only got one entry. My M4 boots from a floppy to a FreHd (my entry). My 4P boots directly from a M3SE (not entered in the poll).
    Mike
    Lots of 4D owners here!
    Jan 2014
    Western North Carolina, USA
    1,140
    Got three 4P's, one with no drives for parts, one with DSDD, and one with an HxC.
    Bughlt: Sckmud
    Quote Originally Posted by pski View Post
    Or people that upgraded to a DS drive since for a time they were inexpensive and easy to get from old IBM PCs and compatibles and you could use your old floppies. I remember back in 1985 or 1986 (I can't remember when I did it) when I upgraded to DSQD drives I replaced drive 1 first and converted my floppies and then replaced drive 0. I used the original Model 4 drives for an SBC that I expanded from a minimal system into one that could run CP/M. I have no idea what happened to it.
    Leaving it at 40 track double sided solves a few pain points you have with alien disks, since you cant easily double step the drive while booting.
    Jun 2015
    Sioux Falls SD
    213
    I have 2 4Ps. One has DS 3.5" 80-track drives and the other has 5.25" DSDD 40-track drives. But can only vote once.
    I have a Model 4P with (2) SSDD drives. I was going to upgrade them to DS, but decided not to.
    Most of my software doesn't need the extra space, but for the few that do, I use my TRS80 emulators.
    Using the emulator, it is very easy to convert and test many different formats of disks for Trs80 Doses and CP/M.
    Morisset, NSW Australia
    243
    Quote Originally Posted by Alphasite View Post
    It sort-of feels moot modifying drives 0 or 1 now, given the alternate storage options. I have external DS drives, enjoy the masochism of xmodem transfers over serial (though I will get a FreHD one of these years), so drive 0 really is just for booting.
    I clicked "other" because I have two answers:
    1) My Model 4P has its original SSDD 40 track drives.
    2) I upgraded my Model 4 gate array model with dual DSDD 40 track drives, but it normally boots from a FreHD. I made an adapter board to have both the original mask ROM and a FreHD-boot EPROM installed, with a toggle switch poking through the vents on top to let me select either ROM.
