Results 1 to 10 of 17
Thread: Easier Gotek on Tandy systems with power-in-cable.
    Mar 2016
    Georgia, USA
    502
    Default Easier Gotek on Tandy systems with power-in-cable.
    Instead of modifying a power cable on my 1000HX, I simply clipped pins 3, 5, 7, 9, 11, 29, 31, and 33 off of the Gotek itself. It was less trouble than counting and clipping wires in the cable itself, and lets me continue to use the original floppy cable.
    They all appear to be connected to GND, and there's still plenty of GND connectors left intact after this modification.
    The gotek still seems 100% functional in a standard PC as well, although I can't promise this is the case in all situations.
    Bloody brilliant
    I forgot to ask, did you use a 1.44 Gotek or a 720KB?
    Mar 2016
    Georgia, USA
    502
    Quote Originally Posted by Towmater View Post
    I used a 1.44 Gotek, with Flashfloppy bios for now. Here are a few photos. I have a 640kb ram expansion that may require a reworking of the power cable, I didn't want to test with it installed, they are rarer than the HX itself!
    I didn't expect the gap in the faceplate, not sure exactly how to handle that, but I think a piece of black foam from a local craft shop will make it look OK-ish. I have to get the 1000hx setup software onto a 720kb floppy before I can actually test this out, but I'm pretty pleased with how it's worked so far.
    Mar 2016
    Georgia, USA
    502
    Also, here's how I modified my Gotek so I could continue to use the factory floppy cable:
    Good idea, all ODD numbered pins on standard floppy drives (and the Gotek) are Ground Pins anyway and all tied together so removing 8 pins is not going to hurt one bit.
    Btw, I highly recommend paying the 11 euros for the HxC firmware, it's better in every way.
    My Retro Collection:
    Mac's: SE, LC630 & Beige G3
    Mar 2016
    Georgia, USA
    502
    Quote Originally Posted by dJOS View Post
    I have several with HXC firmware already, I didn't want to risk an HXC unit in case it all went *poof*.
    Cool, your solution is perfect and wont go bang, as mentioned they are just extra ground lines on normal drives and losing 8 of them wont hurt a bit as their are enough left not to cause issues.
    http://pinouts.ru/HD/InternalDisk_pinout.shtml
    I tried this method in the 1000 HX I've just purchased and it doesn't work. I'm running Flashfloppy 0.14 on the Gotek.
    When I try to read disk A, I've a drive not ready error...If I try to use the Gotke as as the 2nd drive, the original floppy drive makes an horrible noise and doesn't work...THe gotek works very well on my Amiga 2000 test bench...
    Any idea ? What are your jumper settings ? What disk images are you using ? (I tried the HXORIG.IMD converted in HFE)
    Quote Originally Posted by misterdid View Post
    Make sure you set the drive select correctly, on the Gotek S0 equals drive A and S1 equals drive B.
