Results 11 to 20 of 29
Thread: MXV11 CA M8047 small system build CMD CQD and SCSI2SD
    Nov 2014
    Chicagoland
    162
    Quote Originally Posted by PG31 View Post
    I have received the SCSI2SD V5 card and connected it to my CMD CQD card, I'm running the inbuilt qualify drive test on my SCSI2SD with a 4GB SD card installed and it appears to be running ok. . I've been looking at how I get RT-11 installed on the card and I'm a little confused. I found some instructions by 8008guy. Do I copy the image with the SD card installed in my Windows PC? Any tips and advice is greatly appreciated.
    The basics are as follows:
    1) RT11 disk image with an MSCP Disk Handler (DU.SYS)
    2) Configure the disk image to boot off DU. SIMH is a good way to check or set this up. Example: COPY/BOOT DU0:RT11SJ.SYS DU0: Then test to make sure it boots. If you have a image that is configured for another device such as RTV5RL.DSK (RL02 ), that won't work with this controller.
    3) Copy the disk image to the SD directly using a utility that allows you to put the disk image at the same block boundary you have set up the card scsi devices for.
    Typically this means the first scsi drive starts at block 0 on the microSD card and is loaded with block 0 of the disk image. For windows you may need need to locate a utility that does the same as "dd" on unix/linux systems.
    4) Try to boot. During the bootstrap block 0 from the disk image should be loaded starting at address 0. The octal value 240 should be at address 0.
    Liverpool, England
    328
    Thanks Wa2flq, it appears all of my images are for RL02 including what I can find on interweb. I did find one for RK so I suspect this may not work? I'm thinking I could use unetbootin for Windows. I have configured my SD card as two RD54 drives of 256MB (I think anyway!) as devices 1 and 2.
    Apr 2017
    Switzerland
    194
    Use simh to create a disk image for DU. Attach the diskimages of DL and DU to simh and boot from the DL image.
    powermac:simh peter$ ./BIN/pdp11
    Mar 30 21:17:02  pdp11[12140] <Warning>: CGSConnectionByID: 0 is not a valid connection ID.
    Mar 30 21:17:02  pdp11[12140] <Warning>: Invalid Connection ID 0
    2018-03-30 21:17:02.802 pdp11[12140:308452] 21:17:02.802 WARNING:  140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
    PDP-11 simulator V4.0-0 Current        git commit id: 2051422e
    sim>
    sim> set rl rl02
    sim> set rq0 rd54
    sim> attach rl0 rl057.dsk
    sim> attach rq0 du057.dsk
    RQ0: creating new file
    sim> boot rl0
    RT-11FB  V05.07
    .TYPE V5USER.TXT
                                       RT-11 V5.7
        Installation  of  RT-11  Version  5.7 is complete and you are now running
        RT-11 from your system volume.
        Your  system volume is your working volume if you have used the Automatic
        Installation (AI) procedure.  If you  have  installed  RT-11  using  that
        procedure,  Mentec  recommends  you verify the  correct operation of your
        system's software using the VERIFY verification procedure.  You can  only
        perform  VERIFY  on  the  valid target (output) media you used for the AI
        procedure.  Run VERIFY before you run CONFIG.  To run VERIFY,  enter  the
        command:
                                       IND VERIFY
        Mentec  recommends  you  read the file V5NOTE.TXT,  which you can TYPE or
        PRINT.  Also, read the Introduction to RT-11, rewritten for  V5.7,  which
        contains much of the information you need to use RT-11 Version 5.7.
    .R MSCPCK
    ?MSCPCK-I-MU0-TK50  FW Rev Level is 005/HW Rev Level is 001
    ?MSCPCK-W-TQK50 controller below FW Rev 4/HW Rev 6
    .dir
    .ini du:
    DU0:/Initialize; Are you sure? Y
    .copy/system dl: du:
     Files copied:
    DL:STRTAI.COM  to DU:STRTAI.COM
    DL:STRTFB.COM  to DU:STRTFB.COM
    DL:STRTSB.COM  to DU:STRTSB.COM
    DL:STRTXM.COM  to DU:STRTXM.COM
    DL:STRTXB.COM  to DU:STRTXB.COM
    DL:STRTZM.COM  to DU:STRTZM.COM
    DL:STRTZB.COM  to DU:STRTZB.COM
    DL:PIP.SAV     to DU:PIP.SAV
    DL:DUP.SAV     to DU:DUP.SAV
    DL:DIR.SAV     to DU:DIR.SAV
    DL:IND.SAV     to DU:IND.SAV
    DL:RESORC.SAV  to DU:RESORC.SAV
    DL:EDIT.SAV    to DU:EDIT.SAV
    DL:KED.SAV     to DU:KED.SAV
    DL:KEX.SAV     to DU:KEX.SAV
    DL:MACRO.SAV   to DU:MACRO.SAV
    DL:CREF.SAV    to DU:CREF.SAV
    DL:LINK.SAV    to DU:LINK.SAV
    DL:MONMRG.SAV  to DU:MONMRG.SAV
    DL:LIBR.SAV    to DU:LIBR.SAV
    DL:FILEX.SAV   to DU:FILEX.SAV
    DL:SRCCOM.SAV  to DU:SRCCOM.SAV
    DL:BINCOM.SAV  to DU:BINCOM.SAV
    DL:SLP.SAV     to DU:SLP.SAV
    DL:DUMP.SAV    to DU:DUMP.SAV
    DL:SIPP.SAV    to DU:SIPP.SAV
    DL:BUP.SAV     to DU:BUP.SAV
    DL:PAT.SAV     to DU:PAT.SAV
    DL:HELP.SAV    to DU:HELP.SAV
    DL:SYSMAC.SML  to DU:SYSMAC.SML
    DL:SYSLIB.OBJ  to DU:SYSLIB.OBJ
    DL:BATCH.SAV   to DU:BATCH.SAV
    DL:QUEMAN.SAV  to DU:QUEMAN.SAV
    DL:FORMAT.SAV  to DU:FORMAT.SAV
    DL:SETUP.SAV   to DU:SETUP.SAV
    DL:VTCOM.SAV   to DU:VTCOM.SAV
    DL:DATIME.SAV  to DU:DATIME.SAV
    DL:DATIME.MAC  to DU:DATIME.MAC
    DL:DATIME.COM  to DU:DATIME.COM
    DL:LET.SAV     to DU:LET.SAV
    DL:SPLIT.SAV   to DU:SPLIT.SAV
    DL:UCL.SAV     to DU:UCL.SAV
    DL:VBGEXE.SAV  to DU:VBGEXE.SAV
    DL:TERMID.SAV  to DU:TERMID.SAV
    DL:QUEUE.REL   to DU:QUEUE.REL
    DL:RTMON.REL   to DU:RTMON.REL
    DL:SPOOL.REL   to DU:SPOOL.REL
    DL:SPOOL.SAV   to DU:SPOOL.SAV
    DL:VTCOM.REL   to DU:VTCOM.REL
    DL:TRANSF.SAV  to DU:TRANSF.SAV
    DL:TRANSF.TSK  to DU:TRANSF.TSK
    DL:TRANSF.EXE  to DU:TRANSF.EXE
    DL:GIDIS.SAV   to DU:GIDIS.SAV
    DL:ALPH00.FNT  to DU:ALPH00.FNT
    DL:ODT.OBJ     to DU:ODT.OBJ
    DL:VDT.OBJ     to DU:VDT.OBJ
    DL:MDUP.SAV    to DU:MDUP.SAV
    DL:MBOOT.BOT   to DU:MBOOT.BOT
    DL:MBOT16.BOT  to DU:MBOT16.BOT
    DL:MSBOOT.BOT  to DU:MSBOOT.BOT
    DL:MDUP.AI     to DU:MDUP.AI
    DL:MDUP.MM     to DU:MDUP.MM
    DL:MDUP.MS     to DU:MDUP.MS
    DL:MDUP.MT     to DU:MDUP.MT
    DL:MDUP.MU     to DU:MDUP.MU
    DL:DEMOBG.MAC  to DU:DEMOBG.MAC
    DL:DEMOFG.MAC  to DU:DEMOFG.MAC
    DL:DEMOF1.FOR  to DU:DEMOF1.FOR
    DL:DEMOF2.FOR  to DU:DEMOF2.FOR
    DL:DEMOF3.FOR  to DU:DEMOF3.FOR
    DL:DEMOB1.BAS  to DU:DEMOB1.BAS
    DL:DEMOM1.MAC  to DU:DEMOM1.MAC
    DL:DEMOKD.TXT  to DU:DEMOKD.TXT
    DL:VERIFY.COM  to DU:VERIFY.COM
    DL:IVP.COM     to DU:IVP.COM
    DL:IVP.MAC     to DU:IVP.MAC
    DL:MTB.COM     to DU:MTB.COM
    DL:MSB.COM     to DU:MSB.COM
    DL:MS1B.COM    to DU:MS1B.COM
    DL:MUB.COM     to DU:MUB.COM
    DL:FB.MAC      to DU:FB.MAC
    DL:SB.MAC      to DU:SB.MAC
    DL:XB.MAC      to DU:XB.MAC
    DL:XM.MAC      to DU:XM.MAC
    DL:ZB.MAC      to DU:ZB.MAC
    DL:ZM.MAC      to DU:ZM.MAC
    DL:SYSTEM.MLB  to DU:SYSTEM.MLB
    DL:EDTL.MLB    to DU:EDTL.MLB
    DL:BSTRAP.MAC  to DU:BSTRAP.MAC
    DL:EDTG.MAC    to DU:EDTG.MAC
    DL:KMON.MAC    to DU:KMON.MAC
    DL:KMOVLY.MAC  to DU:KMOVLY.MAC
    DL:MTTEMT.MAC  to DU:MTTEMT.MAC
    DL:MTTINT.MAC  to DU:MTTINT.MAC
    DL:RMON.MAC    to DU:RMON.MAC
    DL:TRMTBL.MAC  to DU:TRMTBL.MAC
    DL:USR.MAC     to DU:USR.MAC
    DL:XMSUBS.MAC  to DU:XMSUBS.MAC
    DL:BA.MAC      to DU:BA.MAC
    DL:DL.MAC      to DU:DL.MAC
    DL:DM.MAC      to DU:DM.MAC
    DL:DU.MAC      to DU:DU.MAC
    DL:DW.MAC      to DU:DW.MAC
    DL:DX.MAC      to DU:DX.MAC
    DL:DY.MAC      to DU:DY.MAC
    DL:DZ.MAC      to DU:DZ.MAC
    DL:LD.MAC      to DU:LD.MAC
    DL:LP.MAC      to DU:LP.MAC
    DL:LS.MAC      to DU:LS.MAC
    DL:NC.MAC      to DU:NC.MAC
    DL:NI.MAC      to DU:NI.MAC
    DL:NL.MAC      to DU:NL.MAC
    DL:NQ.MAC      to DU:NQ.MAC
    DL:NU.MAC      to DU:NU.MAC
    DL:RK.MAC      to DU:RK.MAC
    DL:SP.MAC      to DU:SP.MAC
    DL:TJ.MAC      to DU:TJ.MAC
    DL:TM.MAC      to DU:TM.MAC
    DL:TS.MAC      to DU:TS.MAC
    DL:TU.MAC      to DU:TU.MAC
    DL:UM.MAC      to DU:UM.MAC
    DL:VM.MAC      to DU:VM.MAC
    DL:XC.MAC      to DU:XC.MAC
    DL:XL.MAC      to DU:XL.MAC
    DL:FSM.MAC     to DU:FSM.MAC
    DL:EL.MAC      to DU:EL.MAC
    DL:ERROUT.SAV  to DU:ERROUT.SAV
    DL:ELCOPY.MAC  to DU:ELCOPY.MAC
    DL:ELINIT.MAC  to DU:ELINIT.MAC
    DL:ELTASK.MAC  to DU:ELTASK.MAC
    DL:ERRTXT.MAC  to DU:ERRTXT.MAC
    DL:ERROUT.OBJ  to DU:ERROUT.OBJ
    DL:RTSB.MAP    to DU:RTSB.MAP
    DL:RTFB.MAP    to DU:RTFB.MAP
    DL:RTXM.MAP    to DU:RTXM.MAP
    DL:RTZM.MAP    to DU:RTZM.MAP
    DL:SYSGEN.COM  to DU:SYSGEN.COM
    DL:SBFB.ANS    to DU:SBFB.ANS
    DL:XBXM.ANS    to DU:XBXM.ANS
    DL:XMEL.ANS    to DU:XMEL.ANS
    DL:ZBZM.ANS    to DU:ZBZM.ANS
    DL:CONFIG.COM  to DU:CONFIG.COM
    DL:CONFIG.SAV  to DU:CONFIG.SAV
    DL:V5USER.TXT  to DU:V5USER.TXT
    DL:V5NOTE.TXT  to DU:V5NOTE.TXT
    DL:CUSTOM.TXT  to DU:CUSTOM.TXT
    DL:CONSOL.MAC  to DU:CONSOL.MAC
    DL:NITEST.MAC  to DU:NITEST.MAC
    DL:MSCPCK.SAV  to DU:MSCPCK.SAV
    DL:DBGSYM.SAV  to DU:DBGSYM.SAV
    DL:INDEX.SAV   to DU:INDEX.SAV
    DL:INDEXX.SAV  to DU:INDEXX.SAV
    DL:INDEXA.IMG  to DU:INDEXA.IMG
    DL:INDEXB.IMG  to DU:INDEXB.IMG
    DL:INDEX.IDX   to DU:INDEX.IDX
    DL:TECO.SAV    to DU:TECO.SAV
    DL:CR.MAC      to DU:CR.MAC
    DL:CT.MAC      to DU:CT.MAC
    DL:DD.MAC      to DU:DD.MAC
    DL:DP.MAC      to DU:DP.MAC
    DL:DS.MAC      to DU:DS.MAC
    DL:DT.MAC      to DU:DT.MAC
    DL:PC.MAC      to DU:PC.MAC
    DL:PD.MAC      to DU:PD.MAC
    DL:RF.MAC      to DU:RF.MAC
    DL:SWAP.SYS    to DU:SWAP.SYS
    DL:RT11AI.SYS  to DU:RT11AI.SYS
    DL:RT11SB.SYS  to DU:RT11SB.SYS
    DL:RT11FB.SYS  to DU:RT11FB.SYS
    DL:RT11XM.SYS  to DU:RT11XM.SYS
    DL:RT11ZM.SYS  to DU:RT11ZM.SYS
    DL:DL.SYS      to DU:DL.SYS
    DL:DM.SYS      to DU:DM.SYS
    DL:DU.SYS      to DU:DU.SYS
    DL:DW.SYS      to DU:DW.SYS
    DL:DX.SYS      to DU:DX.SYS
    DL:DY.SYS      to DU:DY.SYS
    DL:DZ.SYS      to DU:DZ.SYS
    DL:RK.SYS      to DU:RK.SYS
    DL:LD.SYS      to DU:LD.SYS
    DL:LP.SYS      to DU:LP.SYS
    DL:LS.SYS      to DU:LS.SYS
    DL:MM.SYS      to DU:MM.SYS
    DL:MS.SYS      to DU:MS.SYS
    DL:MT.SYS      to DU:MT.SYS
    DL:MU.SYS      to DU:MU.SYS
    DL:NL.SYS      to DU:NL.SYS
    DL:PI.SYS      to DU:PI.SYS
    DL:SL.SYS      to DU:SL.SYS
    DL:SLMIN.SYS   to DU:SLMIN.SYS
    DL:SP.SYS      to DU:SP.SYS
    DL:VM.SYS      to DU:VM.SYS
    DL:XC.SYS      to DU:XC.SYS
    DL:XL.SYS      to DU:XL.SYS
    DL:DLX.SYS     to DU:DLX.SYS
    DL:DMX.SYS     to DU:DMX.SYS
    DL:DUX.SYS     to DU:DUX.SYS
    DL:DWX.SYS     to DU:DWX.SYS
    DL:DXX.SYS     to DU:DXX.SYS
    DL:DYX.SYS     to DU:DYX.SYS
    DL:DZX.SYS     to DU:DZX.SYS
    DL:LDX.SYS     to DU:LDX.SYS
    DL:LPX.SYS     to DU:LPX.SYS
    DL:LSX.SYS     to DU:LSX.SYS
    DL:MMX.SYS     to DU:MMX.SYS
    DL:MSX.SYS     to DU:MSX.SYS
    DL:MTX.SYS     to DU:MTX.SYS
    DL:MUX.SYS     to DU:MUX.SYS
    DL:NCX.SYS     to DU:NCX.SYS
    DL:NLX.SYS     to DU:NLX.SYS
    DL:NQX.SYS     to DU:NQX.SYS
    DL:NUX.SYS     to DU:NUX.SYS
    DL:PIX.SYS     to DU:PIX.SYS
    DL:RKX.SYS     to DU:RKX.SYS
    DL:SLX.SYS     to DU:SLX.SYS
    DL:SPX.SYS     to DU:SPX.SYS
    DL:UBX.SYS     to DU:UBX.SYS
    DL:VMX.SYS     to DU:VMX.SYS
    DL:XCX.SYS     to DU:XCX.SYS
    DL:XLX.SYS     to DU:XLX.SYS
    DL:SDS.SYS     to DU:SDS.SYS
    DL:SDH.SYS     to DU:SDH.SYS
    DL:SDSX.SYS    to DU:SDSX.SYS
    DL:SDHX.SYS    to DU:SDHX.SYS
    .copy/boot:du du:rt11fb.sys
    To  ? du:
    Simulation stopped, PC: 151722 (BR 151706)
    sim> boot rq0
    RT-11FB  V05.07
    .TYPE V5USER.TXT
                                       RT-11 V5.7
        command:
                                       IND VERIFY
    .R MSCPCK
    Liverpool, England
    328
    Thanks cbscpe, I've not used simh yet so that is something else that I'll have to learn. I'm about to go on a Linux course in work so it'll have to wait until after that. Hopefully I'll be able to build myself a Linux machine and be able to use DD to transfer image to SD card
    Aug 2010
    Silicon Valley USA
    712
    4
    Actually you can run SIMH within the CYGWIN environment on Windows. I download via git and compile via gcc et al the full SIMH source on my Windows 7 64b system.
    If you are interested you can get CYGWIN at www.cygwin.com. It is free. It basically gives you a linux command line terminal window on your Windows box.
    Includes all the unix tools you could ever want (well, almost) including dd, gcc, make, perl, python, git, ...
    You could also go the full VM route and install VirtualBox (www.virtualbox.org, not .com) and then install your favorite linux distro into that environment. Then install simh.
    So lots of ways to get going right now without building a linux hardware box from scratch.
    Dec 2010
    Seattle, WA
    1,758
    If you're a Windows users you don't need to download and install anything else if you run a pre-built SIMH binary distribution.
    I thought at one point I did download the SIMH source code to rebuild it on a Windows system to enable physical access to the host Ethernet through WinPcap, but now I can't remember if that support is already enabled in the pre-built Win32 SIMH binary distributions or not.
    If you want to do the equivalent of 'dd' on a Windows system you do need to install some utilities to do that. I just used something I hacked up myself the last time I needed to do that.
    Aug 2010
    Silicon Valley USA
    712
    4
    Certainly true, there are regular Windows prebuilt binaries zipp'ed up at: https://github.com/simh/Win32-Development-Binaries Usually a few days old at most.
    I've found CYGWIN to be invaluable over the years (I've had it installed on my Windows boxes when I was using WinNT in the late nineties, thru XP, and now Win7).
    It is very easy to install and get running, and obviates the need for a 'real' linux box for most application usage situations (like download, compiling, running unix programs).
    I think MS finally got the hint where I hear in Win10 there is/will be a 'true' linux subsystem, very similar in concept to CYGWIN as I understand it.
    For now however I plan to stick with Win7 until it is no longer feasible. I have seen Win 10 and it does not impress me.
    "I think MS finally got the hint where I hear in Win10 there is/will be a 'true' linux subsystem, very similar in concept to CYGWIN as I understand it."
    I moved my main Windows machines to Windows10 soon after launch though I do keep a machine on Windows7 and one on XP for compatibility needs. Windows10 would be fine except that u$'s compulsory 'upgrades' frequently remove or hide important features (and the latest has severely impacted networking) and add rubbishy non-features. But Windows10 has a Bash Shell which to all intents replaces and improves on Cygwin and really works quite well.
    Liverpool, England
    328
    Thanks, I'll give Cygwin a look. I'm waiting for a new laptop that has Win10 installed so I'll check that out also.
    Windows10 doesn't have the Bash Shell enabled by default and it needs to be the 64-bit version. Have a google for 'windows 10 bash' for details.
