Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Gary Kaufman's IMSAI MPU-A Reproduction Board
    Jun 2014
    Salt Lake City, Utah
    516
    I would be interested in one of each.
    Len
    Spread the joy of Vintage Addiction
    -->www.chronworks.com/<--->www.i8008.net/<--
    4,645
    Quote Originally Posted by snuci View Post
    I thought that was on purpose because they are so close It is an excellent reproduction.
    It says it's a reproduction on the back, with Gary's site's URL. They do look nearly identical to the originals from the front, especially the IMSAI board!
    Well done Gary. This is excellent.
    I'd like to register my interest for 2 x kits (including 2 x PCBs), when available.
    Are you able to post a few notes documenting the steps taken (tools used etc) to get from a scan of the old board, to a clean set of Gerbers and drill file? I recently finished an unrelated reproduction project. It took several hundred hours to accurately measure the placement of tracks and vias, while redrawing the lot in KiCAD. I'd say I did it in about the least efficient way possible!
    Malcolm.
    4,645
    You send the boards to Mile High Test/Gardien Services, pay the fee, and get Gerbers back. They'll digitize all of the layers you'd like (silkscreen, solder mask, etc.). A two-layer S-100 sized board costs around $250. The board has to be stripped of all components. They can do multilayer (4+ layer) boards, but the board is destroyed in the process. Well worth the cost IMO -- as you discovered, there's a *lot* of time in it, and I wouldn't be able to get nearly as much done if I were doing the conversion to Gerbers myself.
    Jul 2014
    New Hampshire, USA
    173
    IMSAI and Altair CPU Boards are now available, please see the posting in the marketplace for-sale section.
    http://www.vcfed.org/forum/forumdisp...-Sale-or-Trade
  6. Default
    6/6/2018
    SUBJECT- IMSAI 8080 PARTS LIST
    If anyone has purchased one of Gary Kaufman's IMSAI 8080 reproduction boards and is in need of a parts list, I have enclosed one if it would be useful to anyone.
    > Charles
    IMSAI_Parts.zip
    6/6/18
    UPDATE-
    Just an Update to the parts list. As I am currently building the board I noticed the 1/2 watt resistors are really too big to fit
    when mounted side by side as in R25-R32, R12-R11, and R8-R7. It would be better to use 1/4 watt resistors throughout.
    You might try...
    ( 1) 291-470-RC
    (19) 291-1K-RC
    (10) 291-4.7K-RC
    These are still carbon film brown body resistors.
    >Charles
    Jun 2009
    Placitas, NM
    150
    Thanks for the list, Dawsoca. I hope to building one of these soon.
    Is there any reason NOT to use 1/4 watt resistors throughout as Charles mentions above? Half-watt seems kinda overkill.
    <*> Jim
    4,645
    The resistor used in the zener regulated supply (the 470R) probably needs to be 1/2W. The rest can be 1/4W.
