+ Reply to Thread
Results 1 to 10 of 77
Thread: More trouble since the Februay VCFED.ORG forum crash.
    Apr 2010
    Albany, OR USA
    861
    Default More trouble since the Februay VCFED.ORG forum crash.
    Looks like this might be a lingering symptom from the trouble we went through in February. Some old theads with links to even older threads don't go anywhere. specifically this thread. Look at post #9. Try to follow the link 1MegXT thread. I get a 404 error because it points to "http://www.vintage-computer.com/vcforum/showthread.php?28128-HIMEMV2-or-equivillent-PROM" which was obviously on the old forum and is not getting forwarded.
    Jan 2014
    Centero
    6,525
    Maybe you could convince the those in charge to give you access to find and fix bad links.
    But there's not much point, I think, in fixing old links. It would be easier for someone encountering that link to do a web search for the information, in my opinion.
    Apr 2010
    Albany, OR USA
    861
    The same thread exists on VCFED.ORG if you change vintage-computer.com/vcforum to vcfed.org/forum it pops right up. Seem like a simple global redirect to me. Pretty sure it was working before the crash.
    Apr 2010
    Albany, OR USA
    861
    So, who do I need to poke here? I was hoping to get a response from a moderator or admin. I believe links to these old threads are important to the continuity of the forum.
    Greg
    New Zealand
    3,895
    4
    Quote Originally Posted by ibmapc View Post
    Greg
    Agreed.
    Oct 2011
    Bedford, NH, USA
    1,531
    Have you tried "reporting" the post with the incorrect link?
    Have you tried sending a PM to mbrutman?
    smp
    You might also first try the little triangle and !. It is an alert to the monitors.
    Apr 2010
    Albany, OR USA
    861
    I'm a little hesitant to use the triangle thing due to the following notice that comes up when it is pressed;
    "Note: This is ONLY to be used to report spam, advertising messages, and problematic (harassment, fighting, or rude) posts."
    I think I'll send a PM to Mike or Evan.
    Greg
    The triangle is for reporting any problem just leave
    a detailed message this is just my opinion..
    Never Bin or sell your old computer's you will regret it!!
    Vic 20 x3,C64 x2,128D,C128 flat deck,A1000 x2,A500 x3,A2000,A600,A1200,Apple ][e,2x Apple][ GS rom 01,03,Apple ][c x4 with only 1 PSU,2x Laser 128EX EX2,Atari 600XL,2x 800XL,130XE w/320 mod With a MyIDE plus,Atari 1040stf w/2.5meg..
    Apr 2010
    Albany, OR USA
    861
    Quote Originally Posted by ChrisUnionNJ View Post
    When you hover over the triangle it clearly says 'Report Post'. That should be clear enough for everybody.
    Click on the thumbnail below and read the note in the red oval!
    This is what comes up when the triangle is pressed.
+ Reply to Thread
  • You may post new threads
  • You may post replies
  • You may edit your posts
