Page 21 of 21 FirstFirst ... 111718192021
Results 201 to 204 of 204
Thread: Show us your Tandy Computers!
  1. #201
    Does the model 1 use RF modulation for it's video out like the CoCo does?
    No, the Model I has a 5-pin DIN connector that carries composite video and +5V, which is needed for the Model I monitor. Otherwise, you can feed the composite signal directly to a standard composite monitor.
  2. #202
    Apr 2007
    Western United States
    596
    The TL/3 finally gets its day on the desk, and will likely be sticking around a while...
  3. #203
    Quote Originally Posted by Cloudschatze View Post
    Seems you have A LOT of MIDI instruments to choose from! 3 Expanders??
  4. #204
    Apr 2007
    596
    Quote Originally Posted by LambdaMikel View Post
    Compared to some of my other setups, this is practically minimalist.
    Here, it's really more about purpose and intent, rather than variety. That is, the Yamaha MU50 is primarily for XG playback, the Roland MT-32 for "LA" playback, and the Roland SC-55 for GM and GS playback.
    I'm also routing the output of the SB16 installed in the TL/3 through the MU50. Compared to other XG modules, the MU50's input is non-effected, but it does provide external analog volume control and visual feedback of the SB16 output, while also saving me the need for yet another analog input (and subsequent need for a mixer) elsewhere. Similarly, the output from the MT-32 is routed through the SC-55.
