Results 1 to 10 of 13
Thread: High Memory Help
    Apr 2018
    Marysville Ohio
    198
    Default High Memory Help
    I trying to get it to load into HIGHMEMORY can anyone help me?
    CONFIG.SYS
    DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
    rem DEVICE=C:\DOS\EMM386.EXE HIGHSCAN
    rem DEVICE=C:\DOS\EMM386.EXE AUTO
    DEVICE=C:\DOS\EMM386.EXE NOEMS
    DOS=HIGH,UMB
    FILES=30
    BUFFERS=20
    LASTDRIVE=Z
    DEVICEHIGH=C:\DOS\SETVER.EXE
    rem DEVICEHIGH=C:\DOS\DISPLAY.SYS CON=(EGA,,2)
    DEVICEHIGH=C:\DRIVER\OAKCDROM.SYS /D:MSCD001
    AUTOEXEC.BAT
    @ECHO OFF
    LH C:\DOS\SMARTDRV.EXE 2048 128
    LH C:\DOS\MSCDEX.EXE /D:MSCD001 /L
    LH C:\MOUSE\MOUSE.COM /Y
    PATH C:\;C:\DOS;C:\NC;C:\PKWARE;C:\WORKS;C:\QB;C:\WORD
    PROMPT $p$g
    SET TEMP=C:\TEMP\
    rem SET SOUND=C:\SB16
    rem SET BLASTER=A220 I5 D1 H5 P330 T6
    rem SET MIDI=SYNTH:1 MAP:G
    rem LH C:\SB16\DIAGNOSE /S
    rem LH C:\SB16\SB16SET /P
    27,640
    So what does the "mem" utility say about where everything is?
    New Zealand
    3,895
    4
    Looks ok to me. What system and version of Dos are you using?
    As Chuck said what does mem say?
    I'd just run memmaker if you are using MSDOS 6.x
    27,640
    That should be invoked with "mem /d", which should map out memory pretty thoroughly.
    Apr 2018
    Marysville Ohio
    198
    I had to change NOEMS to AUTO because NOEMS gave me an ERROR message.
    Here is the output of MEM /D
    Conventional Memory Detail:
    Segment Total Name Type
    00000 1,039 (1K) Interrupt Vector
    00040 271 (0K) ROM Communication Area
    00050 527 (1K) DOS Communication Area
    00070 2,656 (3K) IO System Data
    CON System Device Driver
    AUX System Device Driver
    PRN System Device Driver
    CLOCK$ System Device Driver
    A: - C: System Device Driver
    COM1 System Device Driver
    LPT1 System Device Driver
    LPT2 System Device Driver
    LPT3 System Device Driver
    COM2 System Device Driver
    COM3 System Device Driver
    COM4 System Device Driver
    00116 5,072 (5K) MSDOS System Data
    00253 52,576 (51K) IO System Data
    1,152 (1K) XMSXXXX0 Installed Device=HIMEM
    8,352 (8K) EMMXXXX0 Installed Device=EMM386
    464 (0K) SETVERXX Installed Device=SETVER
    36,048 (35K) MSCD001 Installed Device=OAKCDROM
    1,488 (1K) FILES=30
    256 (0K) FCBS=4
    512 (1K) BUFFERS=20
    2,288 (2K) LASTDRIVE=Z
    1,856 (2K) STACKS=9,128
    00F29 80 (0K) MSDOS System Program
    00F2E 2,656 (3K) COMMAND Program
    00FD4 80 (0K) MSDOS -- Free --
    00FD9 272 (0K) COMMAND Environment
    00FEA 96 (0K) MSDOS -- Free --
    00FF0 29,024 (28K) SMARTDRV Program
    01706 27,952 (27K) MSCDEX Program
    01DD9 17,296 (17K) MOUSE Program
    02212 144 (0K) MEM Environment
    0221B 88,992 (87K) MEM Program
    037D5 422,576 (413K) MSDOS -- Free --
    Memory Summary:
    Type of Memory Total = Used + Free
    Conventional 651,264 139,520 511,744
    Upper 0 0 0
    Reserved 0 0 0
    Extended (XMS)* 66,060,288 2,670,592 63,389,696
    Total memory 66,711,552 2,810,112 63,901,440
    Total under 1 MB 651,264 139,520 511,744
    Handle EMS Name Size
    0 060000
    Total Expanded (EMS) 33,947,648 (33,152K
    Free Expanded (EMS)* 33,554,432 (32,768K
    * EMM386 is using XMS memory to simulate EMS memory as needed.
    Free EMS memory may change as free XMS memory changes.
    Memory accessible using Int 15h 0 (0K)
    Largest executable program size 511,552 (500K)
    Largest free upper memory block 0 (0K)
    MS-DOS is resident in the high memory area.
    XMS version 3.00; driver version 3.16
    EMS version 4.00
    Here is the output of MEM /C
    Modules using memory below 1 MB:
    Name Total = Conventional + Upper Memory
    MSDOS 16,157 (16K) 16,157 (16K) 0 (0K)
    HIMEM 1,168 (1K) 1,168 (1K) 0 (0K)
    EMM386 8,368 (8K) 8,368 (8K) 0 (0K)
    SETVER 480 (0K) 480 (0K) 0 (0K)
    OAKCDROM 36,064 (35K) 36,064 (35K) 0 (0K)
    COMMAND 2,928 (3K) 2,928 (3K) 0 (0K)
    SMARTDRV 29,024 (28K) 29,024 (28K) 0 (0K)
    MSCDEX 27,952 (27K) 27,952 (27K) 0 (0K)
    MOUSE 17,296 (17K) 17,296 (17K) 0 (0K)
    Free 511,744 (500K) 511,744 (500K) 0 (0K)
    Memory Summary:
    Upper 0 0 0
    Reserved 0 0 0
    Apr 2018
    Marysville Ohio
    198
    Quote Originally Posted by Caluser2000 View Post
    I have a Dell inspiron 1525 and using Dos 6.22. I posted the output of MEM. Later I will try MEMMAKER again but before it didn't work.
    Apr 2018
    Marysville Ohio
    198
    I check my Acer ASPIRE ONE and here is the output. There is a few still install low memory.
    MSDOS 16,125 (16K) 16,125 (16K) 0 (0K)
    HIMEM 1,120 (1K) 1,120 (1K) 0 (0K)
    EMM386 4,144 (4K) 4,144 (4K) 0 (0K)
    SETVER 512 (1K) 0 (0K) 512 (1K)
    SMARTDRV 29,024 (28K) 0 (0K) 29,024 (28K)
    Free 648,448 (633K) 613,616 (599K) 34,832 (34K)
    Memory Summary:
    Conventional 655,360 41,744 613,616
    Upper 64,368 29,536 34,832
    Reserved 393,216 393,216 0
    Extended (XMS) 65,995,920 2,409,616 63,586,304
    Total memory 67,108,864 2,874,112 64,234,752
    Total under 1 MB 719,728 71,280 648,448
    Largest executable program size 613,520 (599K)
    Largest free upper memory block 34,736 (34K)
    00253 11,760 (11K) IO System Data
    1,104 (1K) XMSXXXX0 Installed Device=HIMEM
    4,128 (4K) EMMQXXX0 Installed Device=EMM386
    1,488 (1K) FILES=30
    256 (0K) FCBS=4
    512 (1K) BUFFERS=20
    00532 80 (0K) MSDOS System Program
    00537 2,656 (3K) COMMAND Program
    005DD 80 (0K) MSDOS -- Free --
    005E2 272 (0K) COMMAND Environment
    005F3 17,296 (17K) MOUSE Program
    00A2C 144 (0K) MEM Environment
    00A35 88,992 (87K) MEM Program
    01FEF 524,544 (512K) MSDOS -- Free --
    Upper Memory Detail:
    Segment Region Total Name Type
    0D04A 1 496 (0K) IO System Data
    0D069 1 96 (0K) MSDOS -- Free --
    0D06F 1 29,024 (28K) SMARTDRV Program
    0D785 1 34,736 (34K) MSDOS -- Free --
    Memory Summary:
    New Zealand
    3,895
    4
    Jmdlcar its good practice to add your location. Could be someone close by who can assist. Welcome to vcf forum btw.
    Am i really reading your memory right? you have 64MB of ram installed?
    have you tried loading up MSD and looking at the memory map there? you should be able to force scan some areas of memory with "I:"
    strangest thing i ever ran into was dos going crazy on my memory for no reason everything is reading negetive for me but its working!
    another thing to try is the loading order of some of these drivers into high mem. check the largest block available and go from there
    Apr 2018
    Marysville Ohio
    198
    The Dell 64bit was built in 2008 and has 4GB of memory. The Acer 32bit was built in 2009 and has 2GB of memory. The Acer will some in high memory. That why I need a older Computer there is a member that is helping me.
    Not sure how to do this.
