Results 1 to 9 of 9
Thread: XT style power supply?
    Default XT style power supply?
    Hello all!
    I have a 486 motherboard that I'd like to get running again.
    I have a few ISA plug in cards that may still work with it, but I have no case or power supply for it
    I'd guess that the most important step (assuming I can find a video display adapter card) is to connect
    a power supply and see if the BIOS is still alive in EPROM.
    Would anyone have a line on an XT type power supply? I believe that the supply had two power
    connectors that ran to the motherboard.
    I'm at
    bignick@execpc.com
    or on this forum.
    Thank you,
    --KC9KEP
    You want an AT psu. I bought the new Startech 230 watt psu and it works great. That might be overkill for you but it's the only decent new AT psu.
    Sep 2016
    Melbourne, Australia
    431
    For testing I suggest you use one of these adapters with an ATX supply.
    https://www.ebay.com.au/itm/20P-ATX-...sAAOSwjIVafRQk
    It will be less costly if the board turns out to be faulty. Once you know the board works then you should look for an AT style case. Most later AT style cases use a power supply with the same form factor as the common ATX power supplies, so the adapter may come in handy even if the board proves to be a good one.
    Well, I have a Baby-AT PSU but it needs a SPDT power switch (it has spade terminals and a schematic for where to connect them on top). Currently I have it on an e-bay auction but if it keeps failing to sell I'd be willing to pull it and ship it out. I don't need it because all my machines are full XT/AT form factor.
    Mar 2009
    Pleasant Hill, CA USA
    2,462
    Here, buy a brand new AT power supply that will work very well for a 486. Link only $26 and available with Prime shipping.
    Quote Originally Posted by lutiana View Post
    Isn't thaT A ps/2 psu?
    ☞ Time flies like an arrow; fruit flies like a banana.
    Mar 2009
    2,462
    No, I bought one and it's an AT power supply. No idea why they list it as a "PS/2 Power supply".
    That's the one I mentioned.
  9. #9
    Apr 2015
    Austin, Texas
    870
    Quote Originally Posted by David_M View Post
    These won't work unless you have an ATX supply with a -5v rail. Many motherboards back then refuse to even power on if the -5v rail is missing.
    The -5v rail was removed from the ATX spec back in 2003 so you're going to need a very old PSU to get it.
