Results 1 to 10 of 15
Thread: Tandy 1400 Lo-Tech XT-CF Help
  1. Default Tandy 1400 Lo-Tech XT-CF Help
    Hello, this is my first time posting here.
    I have a Tandy 1400LT computer, and I noticed that lo-tech had an XT-CF PCB. So, I made an order with Seeed, and linked them the .zip file on the Lo-Tech wiki, however, they got back to me saying the file was corrupted, and when I went to the file directly, it just redirects to a page: "Something went wrong".
    I have sent Lo-Tech many e-mails about this, yet they are not responding at all. Is there anyone on here that can give me the files for the 1400 XT-CF PCB, or is there someone from Lo-tech here?
    Thank you,
    -abrahamstechnology
    Not sure I follow...you go the BIOS and flash utility from here - https://www.lo-tech.co.uk/wiki/Compa...y_1400_Laptops and it was corrupted?
    Sounds like you can use the generic XT-IDE Universal BIOS, don't necessarily need their version of the files.
    I picked up one of those boards a couple of years ago now...never have gotten around to building it - really should some day!
    Wesley
  3. Default
    Quote Originally Posted by wesleyfurr View Post
    Wesley
    The problem is I don't have the PCB Gerber file itself, and I already made an order with Seed.
    You could try to PM jj_pearce - he's the guy behind Lo-Tech.
    Apr 2017
    N Bellmore, LI
    321
    The lotech card works with the 1400HD and 1400FD only. I contacted them and they said you cant use it on the LT.
    Wanted: Any old clunky 286-P1 machine that has some kind of working battery or replaceable with off the shelf parts. Preferred: 10+lbs 386 machines.
  6. Default
    Mine does have the expansion slot and edge connector, if that's the issue. Or is it a BIOS issue?
    Mar 2006
    Massachusetts, USA
    1,889
    Quote Originally Posted by twistedpneumatic View Post
    All the information on the Lo-tech site implies compatibility with all three Tandy 1400s, including the LT. If it was incompatible they should have noted the information there.
    4,784
    It sounds like OP is trying to run his own *boards* from the Lo-tech design, at Seeed Studio. AFAIK Lo-tech/James Pearce does not actually release the board design files for any of his projects.
    Apparently he did for this particular board...there's a link, but the link doesn't work - https://www.lo-tech.co.uk/wiki/Tandy...xpansion_Slots and this says status is "Released - Open Source" - https://www.lo-tech.co.uk/wiki/Lo-tech_XT-CF_Boards
    Did you ever make any progress with this? I just got a 1400LT as well and, while the floppies are fun, it would be nice to have an easier way to move files to/from the machine.
