Results 1 to 8 of 8
Thread: Fairchild F8 Kit 1 Back in Operation
    Jan 2010
    Central VA
    4,128
    Default Fairchild F8 Kit 1 Back in Operation
    album: https://i.imgur.com/uJp7qsG.jpg
    I'll do a full write-up on this one, but I just wanted to share that I got my F8 Kit up and going! This one came in a heap of scrap, the switches and some capacitors were busted off, someone had stolen then 3850 CPU and 3853 SRAM interface. Fortunately the 3851A PSU with FAIR-BUG was still in its socket -- this is like the 6530 on a KIM-1, it contains mask programmed code and there's no direct replacement. Anyway, I had some time today and decided to clean it up and get it working. I found the following resources very helpful:
    I happened to have a 3850 CPU from the display panel of a piece of old avionics gear, and I bought the 3853 SRAM interface from one of my regular suppliers. I didn't have the manual at first, just the BitSavers schematic, and missed the part about the current loop interface needing to be connected to some of the I/O port pins on the 22/44 connector, but could tell that it was bootstrapping properly from examining the address lines. Once I figured out that I needed to connect pin 10 -> 14 and pin 12 -> 15 on the 22/44 connector, I still had issues with current loop as I'd misread the PRINTER OUT designation as 3 instead of M! No harm done, fortunately I got side-tracked on that and interfaced a MAX232 to the TTL serial lines on the edge connector, but the board was behaving strangely. I suspected bad RAM, so I desoldered all eight 2102s and replaced with sockets. No improvement. I then took another look at the current loop generator and discovered...the data was inverted! It was at that point that I realized my 3 vs. M designation error, so I switched back to current loop...and...success!
    I was using my VT220 in current loop mode at 110 baud for these tests. For that, you want to connect:
    F8 Kit pin 1 -> VT220 pin 5
    F8 Kit pin 2 -> VT220 pin 3
    F8 Kit pin 13 -> VT220 pin 2
    F8 Kit pin M -> VT220 pin 7
    Hooked up to my bench power supply:
    Editing address 0x0000 using FAIR-BUG on the VT220:
    Before replacing the SRAM with sockets:
    Interesting tip for debugging: none of the RAM needs to even be present for the FAIR-BUG monitor to work. Apparently it uses the scratchpad registers exclusively. So, don't go chasing RAM issues if FAIR-BUG doesn't come up! My oscillator was way out of adjustment when I got the board up and going, so I ended up twiddling the adjustment trimpot while punching reset, looking for the question mark prompt to come up. I found both extremes and picked an adjustment in the middle. I haven't verified frequency of the main oscillator yet.
    Jul 2014
    New Hampshire, USA
    139
    Just picked up the same F8 board and a set of documents this past weekend. Now to put together a current loop adapter.
    - Gary
    Jan 2010
    Central VA
    4,128
    Quote Originally Posted by gekaufman View Post
    - Gary
    There's TTL serial available on the 22/44 connector, but you do need to invert at least the transmitted-from-F8 line. Also there are bits on the connector that let you select between 110 and 300 bps, so if you strap it for 300 bps and run a MAX232 or something off the TTL serial pins, you should be able to talk to it from a modern PC as long as the comms program supports going that slow. I've done 300 bps with Prolific type USB->RS232 adapters under Linux, no problem.
  4. Default
    I like that power supply.
    The running F8 is nice, also.
    Mike Willegal
    Jan 2010
    Central VA
    4,128
    Hah, thanks The old Lambda triple-voltage supply has served me well. I use it with a Morrow WunderBuss backplane for testing S-100 boards, as well -- the current limiter will usually stop tantalum caps from totally running away and exploding.
    Jan 2010
    Central VA
    4,128
    Jan 2011
    Vancouver, BC
    3,507
    Neat! I've been kind of looking for one of these for a while but they don't seem to show up much on ebay. I suspect a lot of would be sellers aren't really sure what they are. Nice work!
    Jan 2010
    Central VA
    4,128
    Thanks! I don't think I've ever seen one for sale on eBay. As mentioned, this one came in some industrial scrap I bought from one of my day-job clients. It's a simple enough board for one to build it up on perfboard. Weirdly enough, the FAIR-BUG PSUs do show up. I bought some spares from, IIRC, Unicorn Electronics, which worked fine.
