Results 1 to 10 of 13
Thread: Anyone modded their Tandy 1100FD?
    Mar 2016
    Georgia, USA
    633
    Default Anyone modded their Tandy 1100FD?
    I've disassembled my 1100FD to replace the drive belt, which didn't work, I think I bought the wrong belt.
    While I have been poking around in here, I've noticed there is a LOT of empty space to work with.
    The obvious mod is to replace the (non-working) matsushita drive with an HXC/gotek device. I've picked up some flat ribbon cable connectors and will build an adapter, should be pretty straightforward. I am going to re-route the switches and usb cable and mount them in the metal back panel normally reserved for the 2400 baud modem, which I sadly don't have.
    The second mod I'm considering is replacing the 6v lead-acid battery with a set of nimh or lithium ion cells. I expect the charging circuitry will be incompatible and probably blow the battery up, which would really be a poor outcome in all respects. The easiest way might be to use a cellphone battery pack that can be charged and discharged at the same time and add a little micro hdmi tail or port; would 5v output be sufficient? I'm not sure what the discharge profile looks like for a lead-acid battery, 5v may be too low.
    Third mod would be adding a hard drive; I notice there's a set of solder pads for the 1100HD's hard drive; are these functional? Can an interface be added for xt-ide? Any chance that's an ISA bus? It's only 50 pins, so that's unlikely. It is, however, the number of pins on a compact flash card.
    Please keep us all updated on how this turns out, especially the battery idea. I have 1100's and an 1110's and in a few of them Ive put new belts on the floppy drives, in an effort to keep them original, but I also have a couple where I retrofitted a belt-free floppy with a handcrafted adapter cable, based on docs that I found online, so I suppose that qualifies as a mod, although a kinda lame one.
    I have another 1110 that has a bad HD and was unable to get even that to use a CF card, there was a thread here
    http://www.vcfed.org/forum/archive/i...p/t-43861.html
    that discussed the issues that seemed to be an obstacle to getting that mod working. Maybe a fresh pair of eyes...?
    Mar 2016
    Georgia, USA
    633
    Quote Originally Posted by Juror22 View Post
    That is interesting; the 1100HD connector near the hard drive looks NOTHING like the empty solder pads on my 1100FD. I wonder if the 1100FD solder pads have some other purpose? I should trace them.
    Mar 2016
    Georgia, USA
    633
    5v seems to be insufficient voltage to run the 1100FD.
    Apr 2017
    N Bellmore, LI
    360
    SLA batteries have a cutoff voltage @ 5.5V or there about.
    Wanted: Any old clunky 286-P1 machine that has some kind of working battery or replaceable with off the shelf parts. Preferred: 10+lbs 386 machines.
    Mar 2016
    Georgia, USA
    633
    Quote Originally Posted by twistedpneumatic View Post
    Yeah, that was my guess to begin with.
    I'm going to pick up something like this and try again:
    https://www.pololu.com/product/2566
    It has built-in reverse current protection, which would keep the on-board SLA charging circuit from damaging the lion battery bank, right?
    Aug 2018
    Florida, USA
    4
    Apologies for resurrecting a thread here...
    I just picked a 1100FD to add to my project pile along with a Tandy 1500HD.
    The battery on the 1100FD is easy to do with some 18650s, a 2s BMS and a small buck converter. Should work off the built in charger, too.
    The SLA discharge curve on a 6v battery ranges from 6 to 6.4v though while charging can be as high as 7.2v so it doesn't need to be an exact science. Ill be happy to post results if anyone is interested though I am generally pretty slow on finishing projects.
    I am curious to hear what kind of belts folks are using. Ive bought a couple off ebay for the 1500fd and none have worked. The drive spins but not freely enough. A bit of lube hasnt done the trick. I think I went too small on the belts though. Not my area of expertise so I would appreciate any advice.
    Mar 2016
    Georgia, USA
    633
    Quote Originally Posted by hancat View Post
    Same issue with the belts. I finally found what I think is technically an O-ring but it works perfectly. It is a dead ebay listing, but the description was "New Floppy Drive Belt- Korg, Yamaha, Matsushita EME-213,216"
    I have not had any luck replacing the battery with a direct DC input, it completes the self test but immediately reboots at any voltage from 6 to 7.5.
    I recently got my Tandy 1100FDs working.
    The big problem I found with the floppy drives is that the old belt often melted to the pulleys. You must clean the old belt residue off (I used alcohol and lots of Q-Tips) or when you put the new belt on, the timing will be off because the old belt residue on the pulleys will increase the circumference of the pulleys - but not evenly (the belt only melted to part of the pulleys).
    Once I cleaned the residue off, replacing the belt made the drives work just fine.
    But I did notice a rather high failure rate in DS/DD floppies as I was playing with my 1100FD. The floppys were formatted out of the box and most of them were just fine. But on about 5 out of 20, I got read errors and when I reformatted them in the 1100FD, they had bad areas.
    Doing some searches for "matsushita EME-213AMC" (the model number on the 1100FD floppy drive), was able to locate this: https://www.floppyemulator.com/produ...ushita-eme213/.
    Supposedly, this will provide an interface that will let me use a GOTEK drive in my 1100FD.
