Results 1 to 6 of 6
Thread: Anyone modded their Tandy 1100FD?
    Mar 2016
    Georgia, USA
    459
    Default Anyone modded their Tandy 1100FD?
    I've disassembled my 1100FD to replace the drive belt, which didn't work, I think I bought the wrong belt.
    While I have been poking around in here, I've noticed there is a LOT of empty space to work with.
    The obvious mod is to replace the (non-working) matsushita drive with an HXC/gotek device. I've picked up some flat ribbon cable connectors and will build an adapter, should be pretty straightforward. I am going to re-route the switches and usb cable and mount them in the metal back panel normally reserved for the 2400 baud modem, which I sadly don't have.
    The second mod I'm considering is replacing the 6v lead-acid battery with a set of nimh or lithium ion cells. I expect the charging circuitry will be incompatible and probably blow the battery up, which would really be a poor outcome in all respects. The easiest way might be to use a cellphone battery pack that can be charged and discharged at the same time and add a little micro hdmi tail or port; would 5v output be sufficient? I'm not sure what the discharge profile looks like for a lead-acid battery, 5v may be too low.
    Third mod would be adding a hard drive; I notice there's a set of solder pads for the 1100HD's hard drive; are these functional? Can an interface be added for xt-ide? Any chance that's an ISA bus? It's only 50 pins, so that's unlikely. It is, however, the number of pins on a compact flash card.
    Please keep us all updated on how this turns out, especially the battery idea. I have 1100's and an 1110's and in a few of them Ive put new belts on the floppy drives, in an effort to keep them original, but I also have a couple where I retrofitted a belt-free floppy with a handcrafted adapter cable, based on docs that I found online, so I suppose that qualifies as a mod, although a kinda lame one.
    I have another 1110 that has a bad HD and was unable to get even that to use a CF card, there was a thread here
    http://www.vcfed.org/forum/archive/i...p/t-43861.html
    that discussed the issues that seemed to be an obstacle to getting that mod working. Maybe a fresh pair of eyes...?
    Mar 2016
    Georgia, USA
    459
    Quote Originally Posted by Juror22 View Post
    That is interesting; the 1100HD connector near the hard drive looks NOTHING like the empty solder pads on my 1100FD. I wonder if the 1100FD solder pads have some other purpose? I should trace them.
    Mar 2016
    Georgia, USA
    459
    5v seems to be insufficient voltage to run the 1100FD.
    Apr 2017
    N Bellmore, LI
    283
    SLA batteries have a cutoff voltage @ 5.5V or there about.
    Wanted: Any old clunky 286-P1 machine that has some kind of working battery or replaceable with off the shelf parts. Preferred: 10+lbs 386 machines.
    Mar 2016
    Georgia, USA
    459
    Quote Originally Posted by twistedpneumatic View Post
    Yeah, that was my guess to begin with.
    I'm going to pick up something like this and try again:
    https://www.pololu.com/product/2566
    It has built-in reverse current protection, which would keep the on-board SLA charging circuit from damaging the lion battery bank, right?
