Results 1 to 9 of 9
Thread: Any PC on a chips?
    Apr 2017
    N Bellmore, LI
    321
    Default Any PC on a chips?
    I know they got those NOAC things that are easier to get tjan sliced bread and they made an atari one(flashback 2) and commmodore 64(DTV joystick) so is there a PC on a hip to make some kind of PC laptop that never was.
    IBM 5145 hehe: 640k RAM, 8088, HxC, CF card, and a nice full color active matrix display instead of those wide screen nasty blue buggers from 1987.
    Wanted: Any old clunky 286-P1 machine that has some kind of working battery or replaceable with off the shelf parts. Preferred: 10+lbs 386 machines.
    Dec 2009
    Washington State
    267
    There was something like that a few years back:
    https://fleasystems.com/flea86.html
    Personally I'd love to have a dual-SD card variant that looks like a 5150/5160 with two floppy drives.
    There were many XT, AT, and later system-on-a card computers. There must be hundreds of thousands of RPi sized Windows95 installations out there in Mitsubishi 6xx series CNC controls (including Mazak Fusion) alone.
    Jan 2010
    Central VA
    4,796
    Mar 2016
    Georgia, USA
    576
    Quote Originally Posted by twistedpneumatic View Post
    Considering how well Dosbox/PCEM runs, you have a plethora of cheap options, just about any netbook instantly turns into a great MS-DOS machine.
    Apr 2017
    N Bellmore, LI
    321
    Nah, if it aint running on silicon it aint good enough
    Technically a modern machine is running on silicon, if you want to be technical.
    IBM PS/2 Model 25, NEC V30 8MHz, 640KB RAM, ATI VGA Wonder XL, 2GB SSD, Ethernet, DR DOS 6/GeOS, Xircom PE3 Ethernet
    Oct 2014
    near frankfurt/m, germany
    1,009
  9. Default
    Im in the process of making the MCL86 open source, so if someone wants to integrate it into a project then let me know. The core is cycle accurate to 4.77Mhz so it can run timing-sensitive programs like the 8088 MPH demo.
    https://www.youtube.com/watch?v=b3GkPGZR4BUhttp://
    https://www.youtube.com/watch?v=BUYmz3fqxss
    http://www.microcorelabs.com/mcl86.html
    The Next186 SOC core appears to consume around 95% of the Lattice XO2-7000; perhaps due to the integrated peripherals. The MCL86 8088 core consumes less than 10%,
    -Ted
