Results 1 to 3 of 3
Thread: 4Dos
    Default 4Dos
    I found 4Dos and is it worth using with Dos 6.22?
    May 2009
    Connecticut
    3,858
    Do you plan on running complex batch files? Do you have approximately 80kB of surplus Extended or Expanded memory? If so, you may find it useful.
    Dec 2011
    Dallas, TX
    142
    4DOS was a must have for me back then. If not for no other reason than the improved editing features.
