Results 1 to 1 of 1
Thread: Wanted Packard bell 486 board and Vertical FDD caddy.
    Default Wanted Packard bell 486 board and Vertical FDD caddy.
    I'm trying to recover my Packard bell computer, unfortunately the mobo has serious damage from the battery leakage so I'm not sure I will get it to work. I need to recover a few traces and chips.
    So I guess I will look for a replacement board.
    I believe PB410-PB430 models will work as they are all interchangeable. Not sure about PB450 (most likely no, because it normally came with 3 ISA slot riser, and my case has 4 slots)
    Please correct me if I'm wrong.
    Also looking for a fdd caddy (one where 3.5" fdd sits vertically on the very right side of the desktop. my case is 4x4 Case style)
