Results 1 to 3 of 3
Thread: Tandy 1000 TX
    Default Tandy 1000 TX
    I've never seen a CM-11 without the colors and "High Resolution Monitor" on the door. Is this common? Replacement part for the door maybe?
    https://seattle.craigslist.org/sno/s...586458725.html
    The late production ones were like that -- for example, as seen in the 1993 Radio Shack catalog:
    Quote Originally Posted by Overlordz View Post
    Yep, normal. Tandy got in a "phase" there at the end with branding.
