Results 1 to 10 of 63
Thread: Dec RK8E controller for RK05 wanted
    Question Dec RK8E controller for RK05 wanted
    Hi everyone,
    I'm looking for a Dec RK8E controller the the RK05 hard disk drive.
    Does anyone have one for sale? I don't mind if it's defective...
    Or is there a replica board set to build? Nowadays there are many replica
    projects so maybe someone had redesigned these board?
    Thanks in advance!
    Roland
    Jul 2014
    Rhode Island
    1,116
    Plessey also made an RK05 controller. Schematics here: https://www.pdp8.net/pdp8cgi/query_docs/view.pl?id=551
    The RK8E is on my wish list as well...
    Thanks, that looks great too. With a quick look it seems like
    there are only standard TTL components in that controller.
    It seems that Vince did a great job on the RK8E http://so-much-stuff.com/pdp8/flipchip/Mxxx.htm
    He made drawings of the M7104B, M7105B, M7106B in Eagle.
    I can ask if he actually made and tested these PCB's... Once I talked
    with Vince about the M847, he did draw that one too but never built it.
    So making those PCB's might bring you up into debugging hardware...
    And the problem with all these original DEC boards are the hard to get DEC ans SP chips.
    Aug 2010
    Silicon Valley USA
    743
    4
    Hmmm when I tried to go there I got this:Capture.JPG
    Infected webpage detected
    now
    Feature:
    Web Protection
    This webpage http://so-much-stuff.com/pdp8/flipchip/Mxxx.htm is identified as infected with malware.
    The webpage has been successfully blocked by Antimalware filter and your PC is now safe.
    using BitDefender AntivirusPlus 2018. Don't know yet if it is really true or just a false positive ...
    It seems Bitdefender is the only one which gives an error there:
    https://www.virustotal.com/nl/url/30...is/1526753277/
    So probably a false positive...
    I have the Plessey controller. I purchased it a few years ago. It's untested and currently in the U.S. Roland - if you are interested in it, just send me a PM.
    Great! PM sent!
    Still searching for a RK05 controller... The board set from Mal is not a PDP8/e board set.
    Thanks!
    Alas, no, I haven't built any RK8E boards. Getting the PCBs made is easy these days. Getting the old-stock logic chips can be challenging.
    It might be feasible to do a CPLD version, which would likely fit on a single board .
    Vince
