Results 1 to 10 of 18
Thread: IBM PC AT 286 to 486DX-2 or DX-4 Upgrade
    Default IBM PC AT 286 to 486DX-2 or DX-4 Upgrade
    I have an IBM PC AT 5170 with a 6Mhz 80286. I saw somewhere that someone had upgraded an AT with a 486DX-4. Is there a card or socket upgrade of some sort that I could get to do so? If anyone has one Id be glad to buy it.
    Mar 2009
    Pleasant Hill, CA USA
    2,674
    Pull the motherboard and put in a 486 AT board and you'll be good to go. There is no drop in upgrade that I am aware of. There were some drop in 386 board/cpus that were made to fit in the AT case, but you'd still be replacing most of the innards.
    New Zealand
    3,895
    4
    Extend-It Technologies made a "Make It 486" Processor Upgrade for 286's. I had one. They also bade a 16-bit ISA Memory Expansion card that would fit 16 megs across 4 SIMM's. Great pieces of technology, too bad I didn't keep them.
    Vintage Equipment: IBM 5150 * IBM 5161
    Modern Equipment: ThinkPad X61 * Alienware 15R3 Loaded
    Link to a motherboard that will fit in a 5170? All of them are ATX or for PS/1 systems.
    Mar 2009
    2,674
    Quote Originally Posted by jacobtohahn View Post
    Just look for an AT 486 board on Ebay, most of them should fit in that case fine. I mean, that board is the originator of the AT standard
    Ok, great.
    Trying to determine if this would work in the AT chassis:
    https://rover.ebay.com/rover/0/0/0?m...2F182114419296
    And advice?
    Yes it will fit.
    29,625
    I think the important thing to note is that if you decide to retain the original 5170 planar and "upgrade" it with an add-in 80486 card, it's entirely possible that (a) performance will be lower than a comparable 486 planar and (b) it will suffer compatibility issues.
    Just my .02.
    Just my .02.
    I’ve heard the same thing. Planning on replacing the board.
