Results 1 to 3 of 3
Thread: Roland DG Computer Monitor?
    Default Roland DG Computer Monitor?
    Hello folks,
    I have a quick question for the forums here. I recently came across some older electronics while clearing out my childhood home, and I came across a Roland DG model CB-141 monitor. I care barely remember the old computer, but I believe it was hooked up to an apple II+ at some point in its lifetime. I was under the impression that Roland is mainly (exclusively?) musical gear, and I can find almost zero information on it out there. Basically I'm curious if its a sellable piece and worth the hassle of shipping, or not? It does power on, but thats about all the effort I have put into it thus far.
    Any information is greatly appreciated!
    Thanks!
    Jul 2015
    Vancouver Island
    276
    Roland DG (Digital Group) made a ton of peripherals for home PCs in the '80s - printers, plotters, monitors, MIDI interfaces, sound modules, etc. They also sold home PC type stuff under the Amdek name. AFAIK you can still buy Roland plotters & high-end commercial printing gear.
    Some of their own musical gear could also be hooked up to a monitor. Is this the one you have?
    I had meant to snap a few pictures of it while I was there earlier, but forgot and got caught up in other things. It looks similar to that one, but model CB-141. There is also a slider control on the front.
