Results 1 to 3 of 3
Thread: Win3x Monochrome VGA Display
    Default Win3x Monochrome VGA Display
    I don't know much about VGA hardware and I'm also curious of the workings of Windows 3.1 display drivers.
    This project was created to help expand my knowledge.
    Since monochrome uses only a single page of memory I thought it might be a good place to start.
    After installing the Windows 3.1 VGA Monochrome driver, I tried to create a simple BitBlt function replacement.
    http://turkeys4me.byethost4.com/files/A0000v6.7z
    This example is intended for use with the monochrome VGA driver (vgamono.drv)
    I’ve used the driver with standard VGA without
    Thanks for the input, rmay635703.
    I've adjusted my monochrome Bitblt function.
    http://turkeys4me.byethost4.com/files/A0000v8.7z
    This version may look better when patched into the display driver,
