Results 1 to 2 of 2
Thread: FS: Microcom AX/2400 External RS-232 Modem with Power Adapter, Tested/Working
    Jan 2010
    Central VA
    4,115
    Default FS: Microcom AX/2400 External RS-232 Modem with Power Adapter, Tested/Working
    link: https://www.ebay.com/itm/273272888023
    This is the "ISP end" modem from my Dial-Up at Home With a Line Simulator thread. It's obviously fully functional I tested it both as the called and originating modem. It's in a Microcom box, but it's not the right box for this model -- likely the modem that replaced this one came in it! This modem will work with basically anything that has a RS-232 serial port. It's currently set for Hayes mode (AT command set) and auto-answer after one ring.
    Jan 2010
    Central VA
    4,115
    Price dropped to $5, someone should make this leave my workshop
