Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: IBM 5322 - System/23 - help needed - ROM image
    Jan 2012
    Transilvania, Romania
    27
    Default IBM 5322 - System/23 - help needed - ROM image
    Hi guys,
    I am now the proud owner of an IBM System/23. Unfortunally it seems one of the ROM's ("ROS" as it is called in the technical manual) is broken. Could anyone help me with the ROM image for me to burn a replacement eprom ?
    The power up diagnostics points to the "0B" circuit on the motherboard, i could identify this with the help of this document -> https://gitlab.com/NF6X_Retrocomputi...5324%20MAP.pdf (found on page MAP 1200-5)
    I would love to get this system up and running..
    have a nice Sunday!
    Alex
    Oct 2008
    Kamloops, BC, Canada
    5,538
    41
    how is it broken? Bit rot? broken pin? corrosion?
    = Excellent space heater
    Jan 2012
    27
    Quote Originally Posted by NeXT View Post
    no physical damage can be seen. the power on test fails with "0B" blinking in reverse video pointing out the CRC of this ROM chip is bad... could one bypass this error and let the system run with the bad/incomplete rom basic?
    Oct 2008
    5,538
    41
    Not really. If a ROM is bad it has to be replaced. That's out of my scope of knowledge.
    Nov 2012
    Richmond Hill, Ontario, Canada
    1,087
    Hi Alex,
    I have a System/23 Datamaster and am pretty sure it worked the last time I ran it. I'll have to dig it out and check. Do you know the location of the chip and the specs so I can try to dump it for you? Here's a pic of the internals. Hopefully the ROM will be easy to get to. http://vintagecomputer.ca/wp-content...d-close-up.jpg
    Feb 2011
    NorthWest England (East Pondia)
    2,033
    10
    Quote Originally Posted by alexfloca View Post
    how far in is this check? has it checked any other ROM chips? ROM chips are usually pretty solid, its PROMs that go bad. If there is TTL anywhere then that could have failed. I guess it must have some good ROM if it can run the ROM checksum code?
    G4UGM
    Looking for Analog Computers, Drum Plotters, and Graphics Terminals
    Jan 2012
    27
    The System/23 started and did the power on checks, only the ROM "0B" failed, today i leaved like this for 10 minutes and it died completely, no video. i suspect also there could be one of the logic chips bad in addressing the eproms but unfortunately all chips are marked with ibm codes no 74xxx or 54xxx or similar and with no schematics it will be a hard project, it could also happen that a second eprom is bad now or the ram board or anything else... will not give it up yet, i hope there is someone out there with a circuit diagram for this....
    Sep 2017
    Principality of Xeon
    1,861
    I *used* to have 1. But I thought these had FORTH built in?
  9. #9
    Jan 2012
    27
    ok, monitor gone bad, fixed the monitor... stuck with the ROM/EPROM "0B", can anyone identify the type of ROM / EPROM in the system 23? everything is marked by ibm with custom circuit numbers, eproms, ttl's, processor, everything is custom marked
  10. #10
    30,345
    20
    That's pretty easy.
    My initial guess is that it used the same ROM that the 5150 used. Looking at the service manual, page 2-52, confirms this. The ICs are 24 pin and are identified as having 8KB each for a grand total of 128KB (16 chips).
    The only EPROMs that I'm aware of that will work are the Motorola MC68765 and 68766. There's one other manufacturer that made these 64 Kib 24-pin EPROMs, but it slips my sieve of a mind at the moment. You can get adapters to adapt 28 pin EPROMs/EEPROMs, which are far more common.
    Ah, found it--the WS57C49C is also a match. There may also be a few bipolar PROMs that would work.
