Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: Need some help with a rare Compaq system
  1. #31
    Apr 2015
    Austin, Texas
    1,101
    Quote Originally Posted by Ole Juul View Post
    I probably missed something here, but what's wrong with using CF?
    Yeah, you missed my post where I said to make an image of the existing drive.
  2. #32
    Nov 2016
    Quakertown, Pennsylvania
    185
    Well how else am I supposed to make an image of the drive? I have an IDE to CF adapter and a 4GB card but I don't know how else I'd get an image of the original drive to restore to the CF card.
  3. #33
    Apr 2015
    Austin, Texas
    1,101
    Quote Originally Posted by itsvince725 View Post
    You can make an image of the drive while it's still in the machine using Partition Magic, though that assumes you can connect another drive to the machine. You can always remove the CD-ROM drive temporarily.
    https://winworldpc.com/product/partitionmagic/4x
    An IDE2USB adapter might not work on such an old drive, I have three of them from different manufacturers and it's always a crapshoot if an old drive works with any of them.
    If the drive doesn't work on a USB adapter, you'll need to use a machine with an IDE controller.
  4. #34
    Nov 2016
    185
    In the meantime I'm trying to get the bloat down, but even after deleting everything obvious that I could do without I still only have 222MB free. Is there something I'm missing?
  5. #35
    Apr 2015
    Austin, Texas
    1,101
    Windows 95 shouldn't even come close to filling a 1.8 GB drive.
    The only things I can think of that are eating space is that either there's a huge swapfile (pagefile.sys), or there are OEM partitions on the disk.
  6. #36
    Nov 2016
    185
    There's an OEM diagnostic partition but that's less than 200MB in size so that's not the issue.
  7. #37
    Mar 2009
    DE, USA..
    2,747
    I want that machine, you want some money? I'll come pick it up in person so it's no work for you and pay generously. (PM sent)
    BIOS is accessed by hitting F10 when the block appears in the top right, by the way, if nobody mentioned yet.
    IDE<->USB adapters work on any drive I've ever tried, I doubt there's any restriction. The only thing to keep in mind is it must be set to MASTER if it's too old to have CABLE SELECT (might still need to be set to MASTER either way).
    More commonly known as "Yushatak" - www.yushatak.com
    Focused on 486 and Pentium Machines
    I collect All-In-One PCs and Keyboard PCs, especially Compaq.
