Results 1 to 2 of 2
Thread: MicroDrive Turbo Problem
    Default MicroDrive Turbo Problem
    I have a MicroDrive Turbo IDE interface in my Apple IIe Platinum. I has an adapter to allow two CD cards to be plugged into it. I have two cards that each work fine when they are the only card plugged in but when I plug both of them in, I get the message, "Volume not formatted"
    Does anyone else have this card? If so, does yours work with two CF cards?
    TIA
    Tom L
    Oct 2008
    Kamloops, BC, Canada
    5,337
    41
    Have you somehow set the master/slave jumper incorrectly and both drives are trying to arbitrate in the same location? I know some 40 pin to CF adapters have that jumper.
    = Excellent space heater
