Results 1 to 4 of 4
Thread: Deskpro 66M Audio question
    Oct 2008
    Kamloops, BC, Canada
    5,340
    41
    Default Deskpro 66M Audio question
    I just had this machine drop on my desk so I have done very little yet in terms of research or hunting down the utility diskette for the EISA bus but I immediately noticed that it seems to have integrated audio. The microphone uses a regular 3.5mm jack but the supposed output uses a Mini-Din 8 socket.
    http://i11.photobucket.com/albums/a1...d/IMG_0512.jpg
    I have never come across something like that on a Compaq before, much less a 486. a Quick google is not finding any information about what is going on here. Does that photograph dust off any old memories?
    = Excellent space heater
    28,529
    20
    I've seen the same thing on some AGP cards. I wonder if it doesn't simply match up with this or this.
    May 2009
    Connecticut
    3,909
    6 months ago, there was a thread on it. http://www.vcfed.org/forum/showthrea...M-coming/page4 shows the item and the pinout to build your own.
    Oct 2008
    5,340
    41
    Oh wow, now that is bizarre. Thank you for the link Krebizfan.
    LINE OUT	Mini-DIN-8
    tip		4
    ring		5
    shield		shield
    SPEAKER OUT
    tip		1
    ring		2
    shield		shield
    LINE IN LEFT
    center		6
    shield		shield
    LINE IN RIGHT
    center		7
    shield		shield
    I'll look over that entire thread to see what other info is hiding in there.
