Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Atari ST floppy drive
    Aug 2013
    Keansburg, New Jersey, United States
    898
    There is a mod to make to a PC Floppy Drive to get it to work reliably in an ST. You need to solder a wire between pins 2 and 34 so that the density select switch works as a Disk Change signal to indicate to the ST that you have changed floppies. Otherwise you might ruin disks by writing the wrong information to them. There are articles out there on doing the mod.
    -----[ Al ]-----
    3 - TRS-80 Model I, TRS-80 Model 4D, LNW-80 Model I, Coco, 3 - Coco 2, Coco 3, 2 - Tano Dragon 64, C64, C64c, C128, 2 - Atari 800XL,
    Atari 520-ST, Atari Mega-2 ST, Amiga 1000, TS-1000, TS-2068, ZX-Spectrum, IBM 5150, 2 - Apple ][gs, Laser 128, and a butt load of Macs and Intel PCs.
    Sep 2012
    Indiana, USA
    433
    Yeah, I have several PC floppy drives that work fine with the ST, but they don't have that weird front fascia and eject button, so they can't be mounted internally without modifying the case. I have made a floppy ribbon and power cable extensions to feed out through the empty floppy opening and have a drive perched on top of the machine. Works just fine, but it's just temporary.
