Results 1 to 7 of 7
Thread: Windows 98 Driver Issue
    Jul 2018
    Raxacoricofallapatorius
    5
    Default Windows 98 Driver Issue
    Hi,
    I recently acquired a Windows 98 SE PC. However it had no means of connecting to the internet. I found a suitable PCI adapter (Trendnet TEG-PCITXR). It came with a CD containing the required drivers, however when I went to install them the PC said it was missing the required files from the Operating system. I managed to find a Windows 98 SE Install disc. It did not find the required files though.
    If anyone has any ideas on how to resolve this please let me know.
    Many Thanks,
    Palisades
    Sep 2008
    Walled Lake, MI
    3,543
    6
    Quote Originally Posted by PalisadesPal View Post
    Hi,
    Many Thanks,
    Palisades
    Pal,
    A little more info please. Installing drivers on W98 can be tricky and downright frustrating at times. There are procedures that need to be observed. Installing 3rd party drivers via the components' install routine does not always deliver the desired results, as you have recently discovered. Sometimes you need to use Windows 'Add Hardware' provision within the W98 Control Panel and forgo the installation CD. Give it a shot and let us know how it goes.
    When you say suitable what is it suitable for? WIN98? Are you certain about that?
    Jan 2013
    Marietta, GA
    2,750
    Check to see if the Windows CAB files are already on your hard drive somewhere. With OEM installs it was common to place them in C:\windows\options\cabs. If they are, then when Windows needs to install a file from the Windows CD then just point it to that folder.
    I'm not sure if all Windows 98 CDs actually match, but usually point it to d:\setup or wherever the Windows 98 setup CABs are.
    Exactly what file is it asking for? It might be confused and asking for a file that isn't actually part of Windows 98.
    You may have better success with the actual Realtek drivers... since its an RTL8169 based card I don't know which model but you should be able to determine by looking at the chip on the card... http://www.realtek.com.tw/products/p...Level=5&Conn=4
    Jul 2018
    5
    Hi,
    I have managed to get the drivers installed, thanks for the help. However, I am still having issues setting up an internet connection. I have a cable running from my wireless router into the network adapter. Any ideas as to how I can get an internet connection established would be greatly appreciated.
    Many Thanks,
    Palisades
    Sep 2008
    Walled Lake, MI
    3,543
    6
    Hi,
    Many Thanks,
    Palisades
    See if this helps: http://www.windowsnetworking.com/j_helmig/win98.htm
Tags for this Thread
