Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Latest score: Compaq Portable 486c
    Quote Originally Posted by compaqportableplus View Post
    Very nice! Definitely need to find me one of these someday. I’m a huge Compaq fan (as If that’s not obvious by my username).
    You have confirmed my suspicion about leaky caps being the cause of the very common “white LCD” problem on these.
    I realize the machine is 26-27 years old but I have a 47 year old Sony stereo and many vintage computers in their 30s that all the caps were fine in. It may be a issue with the caps or the LCD design IMO that causes them to fail sooner than other vintage equipment. All the caps were leakers, no sign of pressure problems or bulging. They appear to short when finally dried out, dragging down the power rail supplied by the video card. A transistor on the video card got so hot it started desoldering itself, but I tested it and it's fine. I replaced them with 1 step higher voltage across the board.
    I use all my machines periodically to ensure I'm keeping the alu oxide up in the caps. As many of you know caps need to be used once in awhile to be kept healthy.
    Oct 2016
    Illinois, USA
    443
    Fascinating! I didn't even know there was another past the 386. Great find!
    Jul 2018
    Newcastle, Australia
    29
    Quote Originally Posted by norm8332 View Post
    I did not know about this. How often is once in a while? monthly, quarterly, yearly?
    Quote Originally Posted by cb2000 View Post
    It is usually buried in spec sheets.. Usage avoids the need for reformation. A few hours of on time every three-four years should keep them viable. It is best summarized here:
    https://www.badcaps.net/forum/showthread.php?t=50530
    Jul 2018
    29
    Thanks for that, every few years is all good. I was a bit worried because some old things I have don't get turned on for months.
    Is Wiki correct in that it states the computer has two EISA slots (as opposed to ISA slots)?
    That’s correct. Have a look at this:
    https://books.google.com/books?id=8j...0world&f=false
    Check out that price too!
    Compaq - “It simply works better”
    Thanks for the linkage! Man the Dolch had six EISA slots.... You could use that as a mini-server!
