Results 1 to 7 of 7
Thread: IBM PS/2 Model 70 Restoration
    Default IBM PS/2 Model 70 Restoration
    Hello all!
    I have recently acquired an IBM PS/2 Model 70 in working order, aside from the typical CMOS battery failure and configuration loss. I was wondering what people typically do for modern replacement batteries with the model 70s, and I was also wondering where I might find a copy of the reference diskette, as well as any possible diagnostic diskettes so I can see what still works on the machine and what doesn't.
    Thanks in advance!
    Sep 2003
    Ohio/USA
    7,341
    There are camera batteries that are 100% compatible:
    Duracell Ever Ready Panasonic Kodak Varta Ray-O-Vac Sanyo
    DL223A EL223AP CR-P2 K223LA VL223 PC223 CR-P2
    Awesome! That's about the only other thing I found, so I guess that settles that. Do I have to solder on wires myself or are the end caps removable on the old battery?
    Quote Originally Posted by p4rsec View Post
    Hello all!
    Thanks in advance!
    http://ps-2.kev009.com/ohlandl/8573/8573-P70.html
    http://ps-2.kev009.com/ohlandl/config/refdisk.html
    Ah, yeah I found those webpages after I posted this. However, I still wanted to be 100% sure on how the battery would work, e.g. how on earth to install it. I guess some soldering may be in order, unless the ends on the battery can be removed. I haven't opened it back up to look at it yet.
    OH! After getting one I see it's just a drop-in replacement. That's fantastic! Now to create a ref disk floppy...
