Results 1 to 10 of 11
Thread: How to LLF an IDE HDD in MS-DOS 6.22
    Cool How to LLF an IDE HDD in MS-DOS 6.22
    I acquired a Quantum Big Foot months ago. The one PC I have with BIOS LLF cannot handle this HDD. FDISK also fails.
    Any suggestions on a MS-DOS LLF tool?
    Thanks!
    3,352
    For IDE drives up to 127GB, MAXLLF is usually the best tool.
    If MAXLLF does not recognize or wipe the drive, and a Big Foot should work fine, then likely the drive is dead. But double check the IDE controller and double check and re double check the cables.
    Will try today! Thanks!
    Aug 2013
    Philadelphia,PA area
    115
    I thought IDE drives don't get Low Level Formatted. You skip the BIOS format and just FDISK and Format them in DOS.
    Tom
    Technically you are correct. MAXLLF does not do a LLF in the traditional sense, i.e., write out the tracks and indices, etc. That can only be done with highly specific, expensive equipment that the factory uses. It basically writes zeroes to all the sectors and forces the bad or weak sectors to be remapped to spare sectors.
    3,352
    Technically it just wipes the drive, but it zeros problematic MBRs and forces bad sectors to remap, so it is still a good way to test and prepare old drives. Since MAXLLF also bypasses DOS and BIOS it is a good way to test IDE hardware communications.
    33,437
    If the drive isn't recognized by your BIOS (i.e. doesn't respond), no software will save you. In my experience, this is often how the Bigfoot drives failed.
    It is recognized and partitions show up in FDISK. I has a non DOS partition that I cannot remove with FDISK. Will try MAXLLF at some point this week. Got sidetracked.
    33,437
    You can clobber the partition table very easily using nothing more than the DEBUG utility. That will allow you to re-partition the disk.
    I'm wondering if all those "LLF" programs for modern drives (and Quantum Bigfoot counts as "modern" here) can actually do anything more than eg. "cat /dev/zero > /dev/hda"...
