Results 11 to 20 of 22
Thread: Nerds
    Sure. The problem is the part where it's actually harder to find things without the search bar than it was in Windows 95. Like the way they moved like a quarter of the system settings into the Settings application, but not the rest, which you still need the Control Panel to access, but they removed the Control Panel from its prominent place in the Start menu (and, in 10, even from its place in the right-click-on-the-Start-menu menu that it never tells you about) and hid it in a subfolder in the applications list because they want you to use the Settings application that doesn't have the majority of the functionality that the Control Panel does instead. That is...not great.
    Computers: Amiga 1200, DEC VAXStation 4000/60, DEC MicroPDP-11/73
    Synthesizers: Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, E-mu Proteus/2, Moog Satellite, Oberheim SEM
    "'Legacy code' often differs from its suggested alternative by actually working and scaling." - Bjarne Stroustrup
    Aug 2006
    Chicagoland, Illinois, USA
    5,856
    Quote Originally Posted by commodorejohn View Post
    Yes, but the search bar is always available, so this isn't actually an issue (unless you use assistive technology and cannot type/use the search bar).
    Offering a bounty for:
    Just because they made one thing better doesn't make it cool that they made everything else worse, man.
    Apr 2018
    Los Angeles, CA
    666
    But that's an improvement. That's not a fault of Windows 10, it's a fault of Windows 95 not having that feature. That's a GOOD feature. It's way, way faster to type what you want to launch than to go hunting for it.
    I actually wasn't complaining about the search feature, I prefer it to the menu system.
    But john does make a good point, that without the search, it's much harder to find your way around... I'm not even sure if you can get anywhere without it, which is fine if you know what you're looking for already (which i do since i've used windows forever), but if you don't.. that might be a problem.
    Just for the record on this whole thing, as I stated from the start, I actually prefer windows 10 to every other version of windows. For instance, windows 10 is the first version of windows that actually worked properly with a laptop and dual screens/docking. But, as well, I hated windows 8.0 more than every other version of windows.. (I never used ME even though I had a copy, and I was okay with Vista)
    -- Brian
    Systems: Amstad PCW 8256, Apple IIe/II+/Mac+/Mac 512k, Atari 800/520STFM, Commodore 64/Amiga 3000/PET 4032/SX-64, IBM PS/1 2121-B82, Kaypro II, Osborne 1, Tandy 1000 SX, TI-99/4A, TRS-80 Model 4 GA
  5. #15
    How does Windows 10's search-as-you-type functionality really improve on the one in Windows 7?
    Like you guys I find the text search much easier and faster than crawling through the menus, so I use it constantly in both systems (7 at home, 10 at work), and I can't really think of anything that makes it noticeably better or more useful in 10. *shrugs*
    int10h.org :: :: :: blog
  6. #16
    Aug 2006
    5,856
    Quote Originally Posted by VileR View Post
    It's identical, actually. The comparison, I thought, was to Windows 8 and earlier.
  7. #17
    Apr 2018
    Los Angeles, CA
    666
    I think some of the complaints was that with windows 10 you rely on the search more than you did with windows 7.
    Basically it's the same. Although, windows 10 search expands on the search functionality in Windows 7. Windows 7 would only search apps and files/folders where-as windows 10 search will do all that (and i've found it to do it better, meaning more ways to find the same application or specific areas in settings) along with including internet/store searching (for better or worse).
    Windows 10 is pretty much the best features of Windows 7 and Windows 8 combined (windows 8 removed a bunch of functionality that came back in windows 8.1 and later 10), with a much cleaner UI and more modern functionality. Windows 8 had the problem that microsoft thought we all wanted a tablet UI on our desktop and removed much of the desktop UI.
    -- Brian
  8. #18
    I don't know about 10 having a cleaner UI; there's that schizophrenic "two of everything" syndrome where most of the internal dialogs, applets, etc. have both "old-style" and "new-style" versions, which also never seem to be consistent in which options are available and how they're organized. (And when I use the search to find them, there's no telling in which one I'd end up without memorizing the specific differences in icon styles or wording, or whatever.)
    If they got rid of that all that jarring inconsistency then UI-wise I'd be a happy camper.
  9. #19
    In other words: CLI is better than GUI.
  10. #20
    I've been using Everything for searches on all my machines for nearly ten years. It's FAST, complete and highly configurable.
    http://www.voidtools.com/
