Results 1 to 10 of 14
Thread: Ac lo, dc lo
    Default Ac lo, dc lo
    Hi,
    In documentation we find explanations about power up and down sequences. The documentation talks about "AC in spec and DC in spec" . I Would like to know what "spec" means exactly ..For AC it is frequency , voltage range? . I think that for DC it is only voltage range but not sure...Where can I find this kind of informations, I would like to simulate these signals .
    Thanks in advance.
    I created a summary PDF of the mainframe troubleshooting guide by removing all but the pages I needed to support my PDP 11/40.
    http://vintagecomputer.net/digital/P...uide_Dec76.pdf
    Basically AC LO and DC LO are measured from test points on the wirewrap side of the CPU backplane, or other spots depending on the system you're working on. Here is a pic from my PDP 11/40.
    http://vintagecomputer.net/digital/p...e_DC-input.jpg
    The troubleshooting guide will tell you what the voltages should be. The system will bring DC or AC LO down if something is detected to be wrong. The values of at least 3.x volts are typical of a "good" AC LO or DC LO. In the case of a h742a power supply attached to a PDP 11/40 system I think it'd be more like 4.8v. AC LO and DC LO I think should measure very close to each other, if one is a lot less than the other there is a problem. BUT your system may vary.
    More
    http://vintagecomputer.net/browse_thread.cfm?id=178
    b
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Thanks a lot for the PDF, really interesting. But ,my question was not clear, I am talking about the electrical part that make AC or DC LO asserted. When you say "The system will bring DC or AC LO down if something is detected to be wrong". What do you call "something to be wrong" ? I suppose that there is a measure inside the power supply that compare the output voltage and a reference value , if output voltage is below reference , then DC LO is asserted . I would like to know the reason (and caracteristics) that can cause DC LO or AC LO asserted.
    Sep 2016
    Westminster, Colorado
    37
    Quote Originally Posted by Activmaker View Post
    Hi,
    Thanks in advance.
    I doubt the AC frequency would be measured, since it isn't meaningful to operation (except perhaps to the clock). Linear power supplies attach line voltage to one side of a transformer, take the stepped-down output from the transformer and feed it to a bridge rectifier and (large) electrolytic cap to clean up the ripple. This is *probably* where the voltage for ACLO is measured. It could also be measured at line voltage, but high voltage AC comparators are difficult to build and fiddly to operate.
    The ACLO threshold is probably an input referred ~85VAC, depending on how much margin there is between the output of the rectifier and the dropout voltage of the regulator for line voltage.
    DCLO would just be comparators off one or more of the voltage rails probably set to -10% of nominal.
    CW
    With all due respect, Bitly ... in the context of the question your response is off the mark to the question. AC LO and DC LO are Digital Equipment Corp-specific terms that have nothing directly to do with the AC DC voltages in a power supply. The abridged manual link I supplied has more detail. Why they called these test points AC LO and DC LO is a different story. I am not a DEC expert btw, but enough at least to have repaired a number of DEC UNIBUS systems and learned a lot that way. There are others here who really know there stuff and who can get into the AC LO DC LO purpose specific to a case. If you read the manuals for a CPU card (for example) they're designed to detect certain conditions and force a "DC LO" or "AC LO" response on the UNIBUS backplane, used to signal the source of the problem.
    b
    @ BillDeg:
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    That's just it, it's NOT used to indicate an electrical failure. These are labels *called* AC LO and DC LO, they're not the actual AC nor DC measurements at all. Capiche? You read AC LO and DC LO off the backplane, not the power supply. They're used as indicator values for troubleshooting. Confusing yes, because there are also points where one can read the exact +/-5V (for example) right next to the AC LO DC LO.
    When the CPU initiates it carries out a series of steps electrically/logically. Those diagrams in the troubleshooting charts outline the various failure points that cause among other things the system to drop the AC LO or DC LO. Each controller card has a manual. It's case by case; a chip being bad, a failure in the power supply, a cable plugged in the wrong way...
    Remove all non essential cards. Power up the system. Measure your voltages off the backplane including AC and DC LO, use the troubleshooting manual to narrow down what the source of the problem is. Get the manual for the component that the troubleshooting guide suggests is the point of failure. IN there, that manual will tell you which thing when it fails causes AC LO or DC LO to fall lower than (often extactly by 50%) "quiescent" the term DEC uses for everything is ok.
    So, what kind of system are we talking about here? Let's see if we can use your case as an example of how to use AC LO and DC LO to troubleshoot.
    @ BillDeg:
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    This AC LO and DC LO is nothing complicated, really. They are signals generated by the PSU (or PSUs if you have several) normally. Possibly any one can generate these signals since they are active low wire-ored. But I have only seen these coming from PSUs. Not IO boards or similar
    It has nothing to do with the frequency. It just measures certain voltages inside the PSU.
    This is the spec (from the 11/05 manual, but I assume it is the same with any PDP-11)
    Well it says High state goes to high. Has to be a typo. Should read Low state goes to High
    So what Bitly wrote is probably quite reasonable.
    And here is the description:
    And the actual circuit in the 11/05 PSU:
    The reason for these signals is obviously to make sure that all PSUs have the correct output and then let the processor out of RESET.
    Here is the description for a PDP-11/05 deals with the power fail and auto-restart using these signals.
    I agree that the origin of the signal is the PSU, but I have found that certain controllers will halve the original value electronically and change the DC LO of AC LO signal in a predictable way to force the system out of quiescence state. That's what I meant. Yes you may have to simply fix the power supply, but it's not always true that the resolution to the problem of a AC LO / DC LO issue is the power supply.
    @ BillDeg:
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Quote Originally Posted by billdeg View Post
    You need to be a bit more elaborate here. What do you mean by "halve the original value electronically"? AC LO and DC LO are logical open collector signals, active low. They are either low or high.
    It would be interesting if you could give examples on controllers that output AC LO / DC LO.
    I thought you'd have come across this effect in your travels, too. In my 11/40 in particular there is a CPU card in the set that cuts the signal in half seemingly by design. When I was knee deep in the thing I would have had it memorized what/where but it has been a year and I'd have to look up the specifics. I am at work but it's in the 11/40 doc somewhere. Note that I have also had issues with my h742a power supply board that caused DC LO to fail "directly".
    I am working on the clock at the moment, but if it's really important I can try to find which 11/40 CPU card effects or contributes to the value of DC LO or AC LO.
    I honestly thought all DEC machines manipulated DC LO and AC LO to indicate there was a problem with selected components, but I am open to being corrected, I just wanted to help the OP'er with my experience.
    b
    @ BillDeg:
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
