Results 1 to 4 of 4
Thread: Gotek
    Default Gotek
    Has anyone ever used a Gotek? Here is a link of one. https://www.ebay.com/itm/3-5-1-44MB-...1c75%7Ciid%3A1
    My question is if I install Dos 6.22 and don't have a real floppy drive will a Gotek work as A: drive and install?
    28,904
    20
    It's been discussed before, so you may want to search for related posts. There's also plenty of information on the web, including alternate firmware possibilities for non-MS-DOS HD floppies.
    As long as you can put Gotek-format images on a flash drive, your system shouldn't see any difference between the Gotek and a real floppy drive.
    Jan 2014
    Freedom City
    6,253
    2
    To directly answer your question, yes.
    Frankly, I found floppies more convenient.
    Jan 2012
    Connecticut, USA
    1,532
    Yes I have them, and have even reflashed the firmware on them. They work. They work on many different platforms for many different formats.
    to answer your question, yes. But it may not be as straightforward as you think till you get used to how to use one(gotek).
