Results 1 to 4 of 4
Thread: Programming graphics on a Power Macintosh
    Dec 2012
    Orlando, FL, USA
    188
    Default Programming graphics on a Power Macintosh
    Hi folks,
    I am playing around with Codewarrior 10 on my Power Macintosh 7300 and all is good. However now I want to do some graphics programming and I am a bit stumped.
    I assume I need to use QuickDraw for some simple 2D graphics right? Or will the Carbon API allow me to do that too? I guess I am asking for resources (online or books) that teach how to draw graphics (put_pixel and what not) on classic MacOS.
    My system is a Power Macintosh 7300 running MacOS 8.5. I am a seasoned programmer so I am not looking for basic C++ tutorials but rather how to access the graphics part of the MacOS.
    Thanks in advance!
    On classic Mac OS, QuickDraw is pretty much your only choice. The choice to use Carbon doesn't change this, and on 8.5 I wouldn't use Carbon unless you update to at least 8.6. There isn't much advantage to it except if you want your apps to run natively on OS X as well.
    This code snippet should give you an idea. Scroll down to the main() section and work your way back up as it initializes a graphics context and a window: https://github.com/gohai/macintosh-c...ter/BitPaint.c
    I use my C128 because I am an ornery, stubborn, retro grouch. -- Bob Masse
    Machine room: http://www.floodgap.com/etc/machines.html
    Dec 2012
    Orlando, FL, USA
    188
    Ah thank you, that program is great. Pretty much what I was looking for. I also found some graphics tutorials on the CodeWarrior 10 reference disk. Between those I should be able to put together something.
    That being said though, I do wonder how Doom (I and II) and Quake (sw rasterizer) managed to get decent speeds. I assume they rendered to an offscreen buffer then just blitted the whole thing to the screen (similar to what the program you linked me to does). I should be able to find somewhere the Doom MacOS source code (now that I think of it).
    You're thinking of GWorlds for off-screen rendering. Probably your fastest means is a 256-colour-mode and heavy use of CopyBits(), which is actually a very fast software blitter. Marathon used this approach, for example.
