Page 2 of 9 FirstFirst 123456 ... LastLast
Results 11 to 20 of 82
Thread: Wanted: Exidy Sorcerer CP/M
    32,528
    Should I dig a Sourcerer floppy out of my sample archive and see what it says?
    Nov 2012
    1,145
    That would be helpful.
    Here's what mine look like:
    http://vintagecomputer.ca/wp-content...211_185504.jpg
    http://vintagecomputer.ca/wp-content...211_185414.jpg
    Mar 2013
    Chaffee, MO
    1,216
    I stumbled across this emulator on the Internet.
    http://www.liaquay.co.uk/
    Larry
    Larry
    The CP/M version looks the same as the two disks images I had..
    There are 4 disk images supplied with this java emulator.
    In the emulator you can start CP/M by entering GO BC00, have to find out where that binary block is coming from. Maybe I can implement it in my emulator.
    32,528
    Here's a copy from my archives of a CP/M disk with Spellbinder on it:
    https://app.box.com/s/tnvh97ybqlgupxqpqr7215h6gncbgwch
    Mar 2013
    Chaffee, MO
    1,216
    THANKS Chuck,
    I was able to access it with cpmtools. I'm hoping my conjured up definition is correct.
    #IMDA EXID1.IMD > EXID1.TXT
    IMageDisk Analyzer 1.18 / Mar 12 2012
    IMD 1.18: 9/08/2018 19:10:38
    Exidy Sorcerer CP/M with Spellbinder SSDD 48 tpi
    Archived by CPG Aug 8, 2018
    Required cylinders: 40
    Required heads : 1
    Data rate : 250kbps
    Est. maximum track: 5541 bytes
    Possible drives/options to write EXID1.IMD :
    5.25" DD 40-track
    Double-step: OFF
    5.25" QD 80-track
    Double-step: ON
    5.25" HD 80-track
    Double-step: ON
    250 kbps -> 300 kbps
    3.5" DD 80-track NOTE: *1
    Double-step: OFF
    3.5" HD 80-track NOTE: *1
    Double-step: OFF
    *1 40 track image will use only first 1/2 of 80-track drive.
    #imdu EXID1.IMD EXID1.RAW /B /E /D >> EXID1.TXT
    IMageDisk Utility 1.18 / Mar 07 2012
    Assuming 1:1 for Binary output
    0/0 250 kbps DD 16x256
    1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
    D D D D D D D D D D D D D D D D
    1/0 D D D D D D00 D D D D D D D D D D
    2/0 DE5 DE5 DE5 DE5 D D DE5 DE5 DE5 DE5 D DE5 DE5 DE5 DE5 D
    3/0 D D D D D D D D D D D D D D D D
    4/0 D D D D D D D D D D D D D D D D
    5/0 D D D D D D D D D D D D D D D D
    6/0 DE5 DE5 D DE5 D D DE5 D DE5 DE5 D DE5 D D DE5 D
    7/0 DE5 D D D D D DE5 D D D D DE5 D D D D
    8/0 D D D D D D D D D D D D D D D D
    9/0 DE5 DE5 D D D D DE5 D D D D DE5 D D D D
    10/0 D D D D D D D D D D D D D D D D
    11/0 D D D D D D D D D D D D D D D D
    12/0 DE5 D D D D D DE5 D D D D DE5 D D D D
    13/0 DE5 D D D D D D D D D D DE5 D D D D
    14/0 DE5 D D D D D DE5 D DE5 D D DE5 D D D D
    15/0 DE5 DE5 D DE5 D D DE5 DE5 DE5 D D DE5 DE5 D D D
    16/0 DE5 D D DE5 D D D D DE5 D D DE5 D D DE5 D
    17/0 DE5 DE5 DE5 DE5 DE5 D DE5 DE5 DE5 DE5 DE5 DE5 DE5 D DE5 DE5
    18/0 DE5 D D DE5 DE5 D DE5 D DE5 DE5 D DE5 D D DE5 D
    19/0 DE5 DE5 D DE5 DE5 D DE5 D DE5 DE5 D DE5 D D DE5 DE5
    20/0 D D D D D D D D DE5 D D D D D D D
    21/0 DE5 DE5 D DE5 DE5 D DE5 DE5 DE5 DE5 D DE5 DE5 D DE5 D
    22/0 D D D DE5 DE5 D D D DE5 DE5 D D D D DE5 DE5
    23/0 D D D DE5 DE5 D D D DE5 DE5 DE5 D D D DE5 DE5
    24/0 D D D DE5 DE5 D D D DE5 DE5 DE5 D D D DE5 DE5
    25/0 D D D DE5 D D D D DE5 DE5 D D D D DE5 D
    26/0 DE5 D D DE5 DE5 D DE5 D DE5 DE5 DE5 DE5 D D DE5 DE5
    27/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    28/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    29/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    30/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    31/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    32/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    33/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    34/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    35/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    36/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    37/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    38/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    39/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
    40 tracks(40/0), 640 sectors (336 Compressed)
    cpmls -f exi1 -D EXID1.RAW
    Name Bytes Recs Attr update create
    BATCH .WPM 2K 7
    BOILER .WPM 2K 4
    COMMAND .HEP 2K 4
    CUESORT .WPM 4K 21
    CUSTLIST.WPF 2K 3
    DEMO1 .WPF 2K 14
    DEMO2 .WPF 2K 10
    DEMO4 .WPF 2K 12
    DISK .HEP 4K 17
    EXCOPY .COM 4K 28
    FILE .DEM 4K 17
    FORMAT .HEP 4K 17
    FORMS .WPM 2K 9
    GETTY . 2K 10
    GETTY .WPF 2K 10
    HE .HEP 2K 3
    MMDEMO .WPF 2K 12
    MMERGE .WPM 2K 14
    PIP .COM 8K 56
    PP .COM 6K 40
    PRINT .HEP 2K 15
    SB .COM 20K 154
    SPACE .TAB 2K 7
    STAT .COM 4K 26
    SYSGEN .COM 2K 8
    #cpmcp -f exi1 EXID1.RAW 0:GETTY.WPF .
    Thanks.
    Larry
    32,528
    I barely located it--it was in my E stack of samples, but between all of the Epson ones, not after the Excalibur samples.
    At least they're vaguely alphabetized.
    The OP (Steven Stengel) is asking for a CP/M disk but does not specify what S-100 floppy disk controller he has installed in his S-100 expansion interface. Steven also sent me a PM asking the same, so I replied asking what interface card he has.
    On the topic of emulation; I have a MAME system running emulating a disk system. I don’t remember where I got it from but if other forum members are interested in getting this to work it’s probably best to start a new thread?
    In the forementioned java emulator I found these disk parameters:
      public static final int SECTORS_PER_TRACK = 16;
      public static final int NUMBER_OF_TRACKS = 77;
      public static final int BYTES_PER_SECTOR = 256+14;
    Mar 2013
    Chaffee, MO
    1,216
    Default Sorcerer Emulator .DSK Images
    Yes, those Emulator files are a bit different than a typical CP/M Image as they have a 13 byte Header before
    each sector's data (256 bytes) followed by a checksum byte (of the previous bytes). THANKS to Chuck(G) for
    helping to locate the actual File's Layout Structure.
    * There a 13 byte HEADER at the beginning of each 256 byte sector that has the
    * following format:
    * First byte = hex FF
    * second byte = cylinder number, hex 00-4F
    * third byte = sector number, hex 0-F
    * fourth through thirteenth bytes = 0
    * Followed by 256 bytes of sector data
    * Followed by 1 byte of arithmetic checksum of the whole 13+256 bytes
    * ...repeat until done...
    * 270 * 16 * 77 = 332640
    * 00000000 FF 00 00 00 00 00 00 00 00 00 00 00 00 CD A2 E1 ................
    * 00000010 FD F9 CD 82 04 01 00 01 2A FA 04 EB D5 C5 CD 3B ........*......;
    * 00000020 04 C1 D1 20 ED 04 78 FE 10 20 0E 06 00 79 B7 20 ... ..x.. ...y.
    * Data at 0x000D = 0xCD is the first of the 256 bytes of RAW data.
    * Remember to toss the checksum byte too.
    I've conjured up a cpmtools definition for the .RAW data from these .DSK images (*.RAW) and have accessed
    the files with cpmtools. My definition for the 256 Byte Sectors, 16 Sectors per Track, and 77 Tracks, with 2 Boot Tracks
    follows:
    # Exidy Sorcerer - SS/DD, ie: 8" - 256 x 16
    # 77 tracks, 1 sides, 16 sectors/track, 256 bytes/sector
    # Bytes on the media = 1*77*16*256 = 315392
    # EXI2 Exidy Sorcerer - SSDD 48 tpi 8" - 256 x 16
    diskdef exi2
    seclen 256
    tracks 77
    sectrk 16
    blocksize 2048
    maxdir 64
    datarate HD
    fm YES
    skew 5
    # offset 8192 # 0x2000 = 8192
    boottrk 2
    os 2.2
    end
    The Directories look sane. I've extracted the BIOS.ASM and CBIOS.ASM and they also look sane.
    cpmls -f exi2 -D disk1.raw
    ADMIN1 .WPF 2K 5
    ASM .COM 10K 65
    BASCNVRT.COM 4K 17
    BASIC .COM 2K 11
    BASIC1 .COM 10K 73
    BASIC2 .COM 10K 67
    BIOS .ASM 12K 92
    BIOS .WPF 12K 92
    CALENDAR.COM 6K 35
    CBIOS .ASM 8K 55
    CHESS .COM 10K 71
    COPYCAT .COM 2K 9
    DBS1 .WPF 4K 19
    DDT .COM 6K 38
    DEVCNVRT.COM 2K 11
    DISKBAS .COM 4K 19
    DISKCOPY.COM 4K 21
    DUMP .ASM 6K 35
    DUMP .COM 2K 4
    ED .COM 8K 49
    EXASM .COM 12K 95
    EXBASIC .COM 24K 190
    EXLINK .COM 6K 45
    FILECOPY.COM 2K 6
    FORMAT .COM 4K 19
    INVADERS.COM 6K 42
    LIBINDEX.COM 4K 27
    LOAD .COM 2K 15
    MAZE .COM 6K 35
    MBASIC .COM 24K 189
    MOVCPM .COM 14K 102
    OBASIC .COM 20K 145
    PATTERN .BAS 2K 2
    PIP .COM 8K 57
    PRINT .WPF 2K 11
    RAY1 .WPF 2K 6
    STAT .COM 4K 24
    SUBMIT .COM 2K 11
    SYSGEN .COM 2K 10
    TOUCH .COM 6K 33
    WP .COM 2K 4
    WP9 .COM 6K 35
    42 Files occupying 284K, 14K Free.
    cpmcp -f exi2 disk1.raw 0:*.asm .
    $ls -alt *.asm
    -rw-r--r-- 1 larry larry 11776 Aug 11 21:36 bios.asm
    -rw-r--r-- 1 larry larry 7040 Aug 11 21:36 cbios.asm
    -rw-r--r-- 1 larry larry 4480 Aug 11 21:36 dump.asm
    BIOS.ASM
    ; MDS I/O DRIVERS FOR CP/M
    ; (FOUR DRIVE SINGLE DENSITY VERSION)
    ; VERSION 1.4 JANUARY, 1978
    VERS EQU 14 ;VERSION 1.4
    ; COPYRIGHT (C) 1978
    ; DIGITAL RESEARCH
    ; BOX 579, PACIFIC GROVE
    ; CALIFORNIA, 93950
    TRUE EQU 0FFFFH ;VALUE OF "TRUE"
    FALSE EQU NOT TRUE ;"FALSE"
    SAMPLE EQU FALSE ;TRUE IF SAMPLE BIOS
    IF SAMPLE
    BIAS EQU 2900H ;SAMPLE PROGRAM IN 16K SYSTEM
    ENDIF
    IF NOT SAMPLE
    BIAS EQU 0000H ;GENERATE RELOCATABLE CP/M SYSTEM
    ENDIF
    PATCH EQU 1500H+BIAS
    ORG PATCH
    CPMB EQU 000H+BIAS ;BASE OF CPM CONSOLE PROCESSOR
    BDOS EQU 806H+BIAS ;BASIC DOS (RESIDENT PORTION)
    CPML EQU $-CPMB ;LENGTH (IN BYTES) OF CPM SYSTEM
    NSECTS EQU CPML/128 ;NUMBER OF SECTORS TO LOAD
    OFFSET EQU 2 ;NUMBER OF DISK TRACKS USED BY CP/M
    CDISK EQU 0004H ;ADDRESS OF LAST LOGGED DISK ON WARM START
    BUFF EQU 0080H ;DEFAULT BUFFER ADDRESS
    RETRY EQU 10 ;MAX RETRIES ON DISK I/O BEFORE ERROR
    ; PERFORM FOLLOWING FUNCTIONS
    ; BOOT COLD START
    ; WBOOT WARM START (SAVE I/O BYTE)
    ; (BOOT AND WBOOT ARE THE SAME FOR MDS)
    ; CONST CONSOLE STATUS
    ; REG-A = 00 IF NO CHARACTER READY
    ; REG-A = FF IF CHARACTER READY
    ; CONIN CONSOLE CHARACTER IN (RESULT IN REG-A)
    ; CONOUT CONSOLE CHARACTER OUT (CHAR IN REG-C)
    ; LIST LIST OUT (CHAR IN REG-C)
    ; PUNCH PUNCH OUT (CHAR IN REG-C)
    ; READER PAPER TAPE READER IN (RESULT TO REG-A)
    ; HOME MOVE TO TRACK 00
    ; (THE FOLLOWING CALLS SET-UP THE IO PARAMETER BLOCK FOR THE
    ; MDS, WHICH IS USED TO PERFORM SUBSEQUENT READS AND WRITES)
    ; SELDSK SELECT DISK GIVEN BY REG-C (0,1,2...)
    ; SETTRK SET TRACK ADDRESS (0,...76) FOR SUBSEQUENT READ/WRITE
    ; SETSEC SET SECTOR ADDRESS (1,...,26) FOR SUBSEQUENT READ/WRITE
    ; SETDMA SET SUBSEQUENT DMA ADDRESS (INITIALLY 80H)
    ; (READ AND WRITE ASSUME PREVIOUS CALLS TO SET UP THE IO PARAMETERS)
    ; READ READ TRACK/SECTOR TO PRESET DMA ADDRESS
    ; WRITE WRITE TRACK/SECTOR FROM PRESET DMA ADDRESS
    ; JUMP VECTOR FOR INDIVIUAL ROUTINES
    JMP BOOT
    WBOOTE: JMP WBOOT
    JMP CONST
    JMP CONIN
    JMP CONOUT
    JMP LIST
    JMP PUNCH
    JMP READER
    JMP HOME
    JMP SELDSK
    JMP SETTRK
    JMP SETSEC
    JMP SETDMA
    JMP READ
    JMP WRITE
    ; END OF CONTROLLER - INDEPENDENT CODE, THE REMAINING SUBROUTINES
    ; ARE TAILORED TO THE PARTICULAR OPERATING ENVIRONMENT, AND MUST
    ; BE ALTERED FOR ANY SYSTEM WHICH DIFFERS FROM THE INTEL MDS.
    ; THE FOLLOWING CODE ASSUMES THE MDS MONITOR EXISTS AT 0F800H
    ; AND USES THE I/O SUBROUTINES WITHIN THE MONITOR
    ; WE ALSO ASSUME THE MDS SYSTEM HAS FOUR DISK DRIVES
    NDISKS EQU 4 ;NUMBER OF DRIVES AVAILABLE
    REVRT EQU 0FDH ;INTERRUPT REVERT PORT
    INTC EQU 0FCH ;INTERRUPT MASK PORT
    ICON EQU 0F3H ;INTERRUPT CONTROL PORT
    INTE EQU 0111$1110B ;ENABLE RST 0(WARM BOOT), RST 7 (MONITOR)
    ; MDS MONITOR EQUATES
    MON80 EQU 0F800H ;MDS MONITOR
    RMON80 EQU 0FF0FH ;RESTART MON80 (BOOT ERROR)
    CI EQU 0F803H ;CONSOLE CHARACTER TO REG-A
    RI EQU 0F806H ;READER IN TO REG-A
    CO EQU 0F809H ;CONSOLE CHAR FROM C TO CONSOLE OUT
    PO EQU 0F80CH ;PUNCH CHAR FROM C TO PUNCH DEVICE
    LO EQU 0F80FH ;LIST FROM C TO LIST DEVICE
    CSTS EQU 0F812H ;CONSOLE STATUS 00/FF TO REGISTER A
    ; DISK PORTS AND COMMANDS
    BASE EQU 78H ;BASE OF DISK COMMAND IO PORTS
    DSTAT EQU BASE ;DISK STATUS (INPUT)
    RTYPE EQU BASE+1 ;RESULT TYPE (INPUT)
    RBYTE EQU BASE+3 ;RESULT BYTE (INPUT)
    ILOW EQU BASE+1 ;IOPB LOW ADDRESS (OUTPUT)
    IHIGH EQU BASE+2 ;IOPB HIGH ADDRESS (OUTPUT)
    READF EQU 4H ;READ FUNCTION
    WRITF EQU 6H ;WRITE FUNCTION
    RECAL EQU 3H ;RECALIBRATE DRIVE
    IORDY EQU 4H ;I/O FINISHED MASK
    CR EQU 0DH ;CARRIAGE RETURN
    LF EQU 0AH ;LINE FEED
    SIGNON: ;SIGNON MESSAGE: XXK CP/M VERS Y.Y
    DB CR,LF,LF
    IF SAMPLE
    DB '16' ;16K EXAMPLE BIOS
    ENDIF
    IF NOT SAMPLE
    DB '00' ;MEMORY SIZE FILLED BY RELOCATOR
    ENDIF
    DB 'K CP/M VERS '
    DB VERS/10+'0','.',VERS MOD 10+'0'
    DB CR,LF,0
    BOOT: ;PRINT SIGNON MESSAGE AND GO TO CCP
    ; (NOTE: MDS BOOT INITIALIZED IOBYTE AT 0003H)
    LXI SP,BUFF+80H
    LXI H,SIGNON
    CALL PRMSG ;PRINT MESSAGE
    XRA A ;CLEAR ACCUMULATOR
    STA CDISK ;SET INITIALLY TO DISK A
    JMP GOCPM ;GO TO CP/M
    WBOOT:; LOADER ON TRACK 0, SECTOR 1, WHICH WILL BE SKIPPED FOR WARM
    ; READ CP/M FROM DISK - ASSUMING THERE IS A 128 BYTE COLD START
    ; START.
    LXI SP,BUFF ;USING DMA - THUS 80 THRU FF AVAILABLE FOR STACK
    MVI C,RETRY ;MAX RETRIES
    PUSH B
    WBOOT0: ;ENTER HERE ON ERROR RETRIES
    LXI B,CPMB ;SET DMA ADDRESS TO START OF DISK SYSTEM
    CALL SETDMA
    MVI C,0 ;BOOT FROM DRIVE 0
    CALL SELDSK
    MVI C,0
    CALL SETTRK ;START WITH TRACK 0
    MVI C,2 ;START READING SECTOR 2
    CALL SETSEC
    ; READ SECTORS, COUNT NSECTS TO ZERO
    POP B ;10-ERROR COUNT
    MVI B,NSECTS
    RDSEC: ;READ NEXT SECTOR
    PUSH B ;SAVE SECTOR COUNT
    CALL READ
    JNZ BOOTERR ;RETRY IF ERRORS OCCUR
    LHLD IOD ;INCREMENT DMA ADDRESS
    LXI D,128 ;SECTOR SIZE
    DAD D ;INCREMENTED DMA ADDRESS IN HL
    MOV B,H
    MOV C,L ;READY FOR CALL TO SET DMA
    CALL SETDMA
    LDA IOS ;SECTOR NUMBER JUST READ
    CPI 26 ;READ LAST SECTOR?
    JC RD1
    ; MUST BE SECTOR 26, ZERO AND GO TO NEXT TRACK
    LDA IOT ;GET TRACK TO REGISTER A
    INR A
    MOV C,A ;READY FOR CALL
    CALL SETTRK
    XRA A ;CLEAR SECTOR NUMBER
    RD1: INR A ;TO NEXT SECTOR
    CALL SETSEC
    POP B ;RECALL SECTOR COUNT
    DCR B ;DONE?
    JNZ RDSEC
    ; DONE WITH THE LOAD, RESET DEFAULT BUFFER ADDRESS
    GOCPM: ;(ENTER HERE FROM COLD START BOOT)
    ; ENABLE RST0 AND RST7
    DI
    MVI A,12H ;INITIALIZE COMMAND
    OUT REVRT
    XRA A
    OUT INTC ;CLEARED
    MVI A,INTE ;RST0 AND RST7 BITS ON
    OUT INTC
    XRA A
    OUT ICON ;INTERRUPT CONTROL
    ; SET DEFAULT BUFFER ADDRESS TO 80H
    LXI B,BUFF
    CALL SETDMA
    ; RESET MONITOR ENTRY POINTS
    MVI A,JMP
    STA 0
    LXI H,WBOOTE
    SHLD 1 ;JMP WBOOT AT LOCATION 00
    STA 5
    LXI H,BDOS
    SHLD 6 ;JMP BDOS AT LOCATION 5
    STA 7*8 ;JMP TO MON80 (MAY HAVE BEEN CHANGED BY DDT)
    LXI H,MON80
    SHLD 7*8+1
    ; LEAVE IOBYTE SET
    ; PREVIOUSLY SELECTED DISK WAS B, SEND PARAMETER TO CPM
    LDA CDISK ;LAST LOGGED DISK NUMBER
    MOV C,A ;SEND TO CCP TO LOG IT IN
    EI
    JMP CPMB
    ; ERROR CONDITION OCCURRED, PRINT MESSAGE AND RETRY
    BOOTERR:
    POP B ;RECALL COUNTS
    DCR C
    JZ BOOTER0
    ; TRY AGAIN
    PUSH B
    JMP WBOOT0
    BOOTER0:
    ; OTHERWISE TOO MANY RETRIES
    LXI H,BOOTMSG
    CALL PRMSG
    JMP RMON80 ;MDS HARDWARE MONITOR
    BOOTMSG:
    DB '?BOOT',0
    CONST: ;CONSOLE STATUS TO REG-A
    ; (EXACTLY THE SAME AS MDS CALL)
    JMP CSTS
    CONIN: ;CONSOLE CHARACTER TO REG-A
    CALL CI
    ANI 7FH ;REMOVE PARITY BIT
    RET
    CONOUT: ;CONSOLE CHARACTER FROM C TO CONSOLE OUT
    JMP CO
    LIST: ;LIST DEVICE OUT
    JMP LO
    PUNCH: ;PUNCH DEVICE OUT
    JMP PO
    READER: ;READER CHARACTER IN TO REG-A
    JMP RI
    HOME: ;MOVE TO HOME POSITION
    ; TREAT AS TRACK 00 SEEK
    MVI C,0
    JMP SETTRK
    SELDSK: ;SELECT DISK GIVEN BY REGISTER C
    ; CP/M HAS CHECKED FOR DISK SELECT 0 - 3, BUT WE MAY HAVE
    ; A SMALLER MDS SYSTEM, SO CHECK AGAIN AND GIVE ERROR
    ; BY CALLING MON80
    MOV A,C
    CPI NDISKS ;TOO LARGE?
    CNC RMON80 ;GIVES #ADDR MESSAGE AT CONSOLE
    ANI 10B ;00 00 FOR DRIVE 0,1 AND 10 10 FOR DRIVE 2,3
    STA DBANK ;TO SELECT DRIVE BANK
    MOV A,C ;00, 01, 10, 11
    ANI 1B ;MDS HAS 0,1 AT 78, 2,3 AT 88
    ORA A ;RESULT 00?
    JZ SETDRIVE
    MVI A,00110000B ;SELECTS DRIVE 1 IN BANK
    SETDRIVE:
    MOV C,A ;SAVE THE FUNCTION
    LXI H,IOF ;IO FUNCTION
    MOV A,M
    ANI 11001111B ;MASK OUT DISK NUMBER
    ORA C ;MASK IN NEW DISK NUMBER
    MOV M,A ;SAVE IT IN IOPB
    RET
    SETTRK: ;SET TRACK ADDRESS GIVEN BY C
    LXI H,IOT
    MOV M,C
    RET
    SETSEC: ;SET SECTOR NUMBER GIVEN BY C
    MOV A,C ;SECTOR NUMBER TO ACCUM
    STA IOS ;STORE SECTOR NUMBER TO IOPB
    RET
    SETDMA: ;SET DMA ADDRESS GIVEN BY REGS B,C
    MOV L,C
    MOV H,B
    SHLD IOD
    RET
    READ: ;READ NEXT DISK RECORD (ASSUMING DISK/TRK/SEC/DMA SET)
    MVI C,READF ;SET TO READ FUNCTION
    CALL SETFUNC
    CALL WAITIO ;PERFORM READ FUNCTION
    RET ;MAY HAVE ERROR SET IN REG-A
    WRITE: ;DISK WRITE FUNCTION
    MVI C,WRITF
    CALL SETFUNC ;SET TO WRITE FUNCTION
    CALL WAITIO
    ; UTILITY SUBROUTINES
    PRMSG: ;PRINT MESSAGE AT H,L TO 0
    MOV A,M
    ORA A ;ZERO?
    RZ
    ; MORE TO PRINT
    PUSH H
    MOV C,A
    CALL CONOUT
    POP H
    INX H
    JMP PRMSG
    SETFUNC:
    ; SET FUNCTION FOR NEXT I/O (COMMAND IN REG-C)
    LXI H,IOF ;IO FUNCTION ADDRESS
    MOV A,M ;GET IT TO ACCUMULATOR FOR MASKING
    ANI 11111000B ;REMOVE PREVIOUS COMMAND
    ORA C ;SET TO NEW COMMAND
    MOV M,A ;REPLACED IN IOPB
    ; THE MDS-800 CONTROLLER REQUIRES DISK BANK BIT IN SECTOR BYTE
    ; MASK THE BIT FROM THE CURRENT I/O FUNCTION
    ANI 00100000B ;MASK THE DISK SELECT BIT
    LXI H,IOS ;ADDRESS THE SECTOR SELECT BYTE
    ORA M ;SELECT PROPER DISK BANK
    MOV M,A ;SET DISK SELECT BIT ON/OFF
    RET
    WAITIO:
    MVI C,RETRY ;MAX RETRIES BEFORE PERM ERROR
    REWAIT:
    ; START THE I/O FUNCTION AND WAIT FOR COMPLETION
    CALL INTYPE ;IN RTYPE
    CALL INBYTE ;CLEARS THE CONTROLLER
    LDA DBANK ;SET BANK FLAGS
    ORA A ;ZERO IF DRIVE 0,1 AND NZ IF 2,3
    MVI A,IOPB AND 0FFH ;LOW ADDRESS FOR IOPB
    MVI B,IOPB SHR 8 ;HIGH ADDRESS FOR IOPB
    JNZ IODR1 ;DRIVE BANK 1?
    OUT ILOW ;LOW ADDRESS TO CONTROLLER
    MOV A,B
    OUT IHIGH ;HIGH ADDRESS
    JMP WAIT0 ;TO WAIT FOR COMPLETE
    IODR1: ;DRIVE BANK 1
    OUT ILOW+10H ;88 FOR DRIVE BANK 10
    MOV A,B
    OUT IHIGH+10H
    WAIT0: CALL INSTAT ;WAIT FOR COMPLETION
    ANI IORDY ;READY?
    JZ WAIT0
    ; CHECK IO COMPLETION OK
    CALL INTYPE ;MUST BE IO COMPLETE (00) UNLINKED
    ; 00 UNLINKED I/O COMPLETE, 01 LINKED I/O COMPLETE (NOT USED)
    ; 10 DISK STATUS CHANGED 11 (NOT USED)
    CPI 10B ;READY STATUS CHANGE?
    JZ WREADY
    ; MUST BE 00 IN THE ACCUMULATOR
    ORA A
    JNZ WERROR ;SOME OTHER CONDITION, RETRY
    ; CHECK I/O ERROR BITS
    CALL INBYTE
    RAL
    JC WREADY ;UNIT NOT READY
    RAR
    ANI 11111110B ;ANY OTHER ERRORS? (DELETED DATA OK)
    JNZ WERROR
    ; READ OR WRITE IS OK, ACCUMULATOR CONTAINS ZERO
    RET
    WREADY: ;NOT READY, TREAT AS ERROR FOR NOW
    CALL INBYTE ;CLEAR RESULT BYTE
    JMP TRYCOUNT
    WERROR: ;RETURN HARDWARE MALFUNCTION (CRC, TRACK, SEEK, ETC.)
    ; THE MDS CONTROLLER HAS RETURNED A BIT IN EACH POSITION
    ; OF THE ACCUMULATOR, CORRESPONDING TO THE CONDITIONS:
    ; 0 - DELETED DATA (ACCEPTED AS OK ABOVE)
    ; 1 - CRC ERROR
    ; 2 - SEEK ERROR
    ; 3 - ADDRESS ERROR (HARDWARE MALFUNCTION)
    ; 4 - DATA OVER/UNDER FLOW (HARDWARE MALFUNCTION)
    ; 5 - WRITE PROTECT (TREATED AS NOT READY)
    ; 6 - WRITE ERROR (HARDWARE MALFUNCTION)
    ; 7 - NOT READY
    ; (ACCUMULATOR BITS ARE NUMBERED 7 6 5 4 3 2 1 0)
    ; IT MAY BE USEFUL TO FILTER OUT THE VARIOUS CONDITIONS,
    ; BUT WE WILL GET A PERMANENT ERROR MESSAGE IF IT IS NOT
    ; RECOVERABLE. IN ANY CASE, THE NOT READY CONDITION IS
    ; TREATED AS A SEPARATE CONDITION FOR LATER IMPROVEMENT
    TRYCOUNT:
    ; REGISTER C CONTAINS RETRY COUNT, DECREMENT 'TIL ZERO
    DCR C
    JNZ REWAIT ;FOR ANOTHER TRY
    ; CANNOT RECOVER FROM ERROR
    MVI A,1 ;ERROR CODE
    RET
    ; INTYPE, INBYTE, INSTAT READ DRIVE BANK 00 OR 10
    INTYPE: LDA DBANK
    ORA A
    JNZ INTYP1 ;SKIP TO BANK 10
    IN RTYPE
    RET
    INTYP1: IN RTYPE+10H ;78 FOR 0,1 88 FOR 2,3
    RET
    INBYTE: LDA DBANK
    ORA A
    JNZ INBYT1
    IN RBYTE
    RET
    INBYT1: IN RBYTE+10H
    RET
    INSTAT: LDA DBANK
    ORA A
    JNZ INSTA1
    IN DSTAT
    RET
    INSTA1: IN DSTAT+10H
    RET
    ; DATA AREAS (MUST BE IN RAM)
    DBANK: DB 0 ;DISK BANK 00 IF DRIVE 0,1
    ; 10 IF DRIVE 2,3
    IOPB: ;IO PARAMETER BLOCK
    DB 80H ;NORMAL I/O OPERATION
    IOF: DB READF ;IO FUNCTION, INITIAL READ
    ION: DB 1 ;NUMBER OF SECTORS TO READ
    IOT: DB OFFSET ;TRACK NUMBER
    IOS: DB 1 ;SECTOR NUMBER
    IOD: DW BUFF ;IO ADDRESS
    END
    Next steps are to extract all files in each *.RAW Image. Zip the Disk*.*, README.1st, Sorcerer Definitions for cpmtools & libdsk,
    and any other information that should be attached.
    And get those zips to Bitsavers, and whoever else is storing any Exidy Sorcerer Files.
    Thanks goes to Chuck(G) for the research of the Image layout, so cpmtools could access the .RAW Images, that were created from
    the 6 ???disk?.dsk images.
    Larry
