Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 82
Thread: Wanted: Exidy Sorcerer CP/M
  1. #51
    Nov 2012
    1,146
    Here are the Exidy/Micropolis drives side-by-side. You can see it's a rebranded Micropolis drive that has been painted and Exidy stickers applied.
    Exidy and Micrpolis drives.jpgExidy branded drive label.jpgMicropolis drive label.jpgBlue paint under Exidy beige enclosure.jpg
  2. #52
    May 2018
    170
    It also looks like they made their own enclosure, which is high enough to have held their
    soft-sectored floppy controller board.
    I expect it is the same controller (or very similar) soft-sector controller to your Display Disk Unit.
    Quote Originally Posted by snuci View Post
    Great series of photos snuci! Thanks for putting those up.
  3. #53
    May 2018
    170
    thanks!
    I have my Supercard Pro set up now, and a good working Tandon TM-100-4M .
    I have a huge backlog of various types of 5" and 8" hard-sectored floppies from many different companies that I'm going to try
    to start imaging and recovering data from, along with some very obscure soft-sectored disks from companies like Milwaukee Computers.
    I'm working with a Sorcerer owner in Canada to recover his 16 sector disks. It isn't clear to me that Kryoflux or the various CF card to Shugart adapters support hard sector media.
    Does that reduce the recovery options to reading on the original machine and drives then copying to a new blank disc or perhaps using PIP to send out the serial port?
  4. #54
    Sep 2006
    Silicon Valley
    2,040
    Quote Originally Posted by exidyboy View Post
    There is little support beyond the Supercard Pro having an option to stop synchronizing the capture with the (presumed) single pulse from the drive's index sensor.
    Along with that is the problem these cards don't actually decode what they are reading in real-time, so there are no retries. You can end up with complete garbage if the head gets clogged
    and not even know it.
    Copying the data out the serial port is generally what people have done it the past with hard-secored media like Northstar and Vector Graphics.
    There is a better chance of recovery too if their drives run a little slow or are misaligned.
    I don't know where the existing Micropolis Exidy disk dumps came from, or how the copies were made.
    Unfortunately, in my world I have a big collection of media, and rarely have the original machine. In some cases, I don't even have one that's close.
  5. #55
    Typically for me I've only just found this thread. I've literally just got my Sorcerer/S100/Micropolis setup running so if I can provide any more info just shout.
    W
    *edit* just for giggles I loaded up the HxCEmulator to convert Larry's CP/M .IMD into an .IMG and .HFE for a Gotek floppy emulator and the Sorcerer actually starts to boot but locks up at around track 6.
    www.binarydinosaurs.co.uk - UK home computer history
    Where RIFA capacitors come to die
    facebook.com/binarydinosaurs
  6. #56
    May 2018
    170
    Quote Originally Posted by Witchy View Post
    W
    It's definitely a hard-sectored controller?
  7. #57
    May 2018
    170
    While looking for a dump of the Micropolis controller ROM to help @whizzi get his system up http://www.vcfed.org/forum/showthrea...Sorcerer-error I stumbled across this program from @deramp to image Micropolis hard sector controller disks from a SOL-20 out the serial port to a PC. Could be a good starting point for you and others like @dutchacorn with hard sector media to transcribe . http://deramp.com/downloads/processo...mage_transfer/
  8. #58
    Nope, mine is soft sectored.
  9. #59
    Mar 2013
    Chaffee, MO
    1,238
    Witchy,
    Is your Soft Sectored system an 8" or 5" Floppy.
    If you can make a .IMD file of it with Dave Dunfield's Imagedisk Ver 1.18, it maybe possible to access the files in the .RAW file
    with cpmtools with this definition:
    # Exidy Sorcerer - SS/DD, ie: 8" - 256 x 16
    # 77 tracks, 1 sides, 16 sectors/track, 256 bytes/sector
    # Bytes on the media = 1*77*16*256 = 315392
    # EXI2  Exidy Sorcerer - SSDD 48 tpi 8" - 256 x 16
    diskdef exi2
      seclen 256
      tracks 77
      sectrk 16
      blocksize 2048
      maxdir 64
      datarate HD
      fm YES
      skew 5
    # offset 8192       # 0x2000 = 8192
      boottrk 2
      os 2.2
    end
    I've used it on some other Images I've located.
    $cpmls -f exi2 -D CPMdisk1.raw
         Name    Bytes   Recs  Attr     update             create
    ASM     .COM    10K     65
    BASCNVRT.COM     4K     17
    BASIC   .COM     2K     11
    BASIC1  .COM    10K     73
    BASIC2  .COM    10K     67
    BIOS    .ASM    12K     92
    CALENDAR.COM     6K     35
    CBIOS   .ASM     8K     55
    CHESS   .COM    10K     71
    DDT     .COM     6K     38
    DEMO    .WPF     2K      3
    DEVCNVRT.COM     2K     11
    DISKBAS .COM     4K     19
    DISKCOPY.COM     4K     21
    DUMP    .ASM     6K     35
    DUMP    .COM     2K      4
    ED      .COM     8K     49
    EXASM   .COM    12K     95
    EXBASIC .COM    24K    190
    EXLINK  .COM     6K     45
    FILECOPY.COM     2K      7
    FORMAT  .COM     4K     19
    INVADERS.COM     6K     42
    LIBINDEX.COM     4K     27
    LOAD    .COM     2K     15
    MAZE    .COM     6K     35
    MBASIC  .COM    24K    189
    MOVCPM  .COM    14K    101
    OBASIC  .COM    20K    145
    PIP     .COM     8K     57
    STAT    .COM     4K     24
    SUBMIT  .COM     2K     11
    SYSGEN  .COM     2K      9
    TOUCH   .COM     6K     33
    WP      .COM     2K      5
    WP9     .COM     6K     35
       36 Files occupying    260K,      38K Free.
    If it's a 5.25" Floppy, I'd really like to get a copy of th .IMD file.
    Thanks.
    Larry
  10. #60
    Were there any harddisk systems for the Exidy ? Preferably with some info on IO addresses and/or controller so I can add it to my ARM Exidy emu.
    I find that little over 300k per floppydisk can be tight assembling large sources, because of the generated PRN file.
