Results 1 to 10 of 14
Thread: Bootable RX01 diskettes with RT-11 and XXDP
    Default Bootable RX01 diskettes with RT-11 and XXDP
    Would greatly appreciate if anyone could provide me with these two diskettes. Still fumbling with my PDP 11/23 system.
    Thank you.
    Al
    4,152
    You're probably better off getting one of the TU58 emulators running with a SLU on your machine. There are lots of premade TU58 tape images for various XXDP diagnostics sets, RT-11, etc. Especially if your RX01s are not known to definitely be working. Nowadays I usually use AK6DN's tu58em
    I understand what you are saying but I have had some problems trying that. I specifically want to see about the diskettes.
    Thank you.
    Al
    4,152
    I/We are happy to help you get TU58 emulation up and going
    I can probably write out RX01s for you -- I've got working RX02 drives on my MINC-23 -- I'm just concerned that you may not get anywhere due to some other system fault.
    Aug 2010
    Silicon Valley USA
    711
    4
    Been around this block before, see: http://www.vcfed.org/forum/showthrea...3-system/page2
    My suspicion is there is something more fundamentally wrong with his system than just the DLV11 interface which does not allow TU58EM emulation to run.
    4,152
    Quote Originally Posted by AK6DN View Post
    Yeah, that would be my main concern, that there's a bigger issue preventing TU58 from working -- which is usually quite reliable. TU58 is almost always the first thing I get working on a new-to-me system.
    I know a lot of people like PDP11GUI and such, but really I find that running XXDP after you've got a basically stable system is the Best Way Forward. I've caught problems with XXDP on systems people had "tested" with PDP11GUI and found to be "fine."
    I very often run the XXDP diagnostics from PDP11GUI. Since diagnostics are in absolute loader format it is very easy to let PDP11GUI load them into memory and run them from address 200. You only need one serial port with the console ODT or emulator working. So in that sense one can test things with PDP11GUI.
    Yes, I would be delighted to get TU58EM running. Figures 1 and 2 show the computer monitor and the TU58 emulation respectively. This attempt was using a KDF11 and booting from a BDV11 board with updated KDF11B ROMs. Figures 2 and 3 show a current attempt this time using a KDF11B (of course no BDV11 board). The KDF11 always had flakey operation with halts occuring randomly. I tried a second KDF11 board and had the same behavior. The KDF11B seems to run stably with no random halts. However I still obviously don't have the TU58 emulation running properly. I recently obtained a Dilog DQ419 floppy controller which I am in the process of interfacing with a Shugart drive. Hence the request for the RX01 bootable diskettes. Further checking shows that the DQ419 will not boot from RX01s so I guess I will change the request to RX02s. I certainly welcome any help in trying to finally end up with a reliable functional system.
    Thank you to those of you who have already offered advice and suggestion.
    Cheers,
    Al
    4,152
    Are you by chance using a USB -> RS-232 adapter on the Windows PC end? I've had hit and miss results with them when talking to old hardware, some are totally fine, some are fine most of the time, and some are pretty flaky. If that's what you're doing and you have another on hand, give it a try.
    There was a mention in the other thread about possible cabling issues. If you don't have a proper DLV11-J style breakout cable, you can run one of John Wilson's adapters:
    http://www.dbit.com/wilson/dlvdb25/
    If you don't want to order your own circuit boards, I've got the bare boards, and I can assemble one for you if you like.
    Oct 2011
    Bedford, NH, USA
    1,530
    I can vouch for the interface adapter that glitch is talking about.
    I have a few of them (from him), and I use mine to attach to an RS232-to-USB adapter that connects to my MacBook Pro.
    No fuss, no muss, no problems. Well worth it.
    smp
